1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Retrieving record name from aSub input/output fields
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 26 Jul 2022 23:53:28 +0000
Update. I think I got it. I had to do the following.
static long func(aSubRecord *prec)
         DBLINK inpa = prec->inpa;
                char *rec_name = inpa.value.pv_link.pvname;
                printf(“Record name in INPA is %s\n”, rec_name);
                return 0;
Sent: Tuesday, July 26, 2022 4:17 PM
Subject: Retrieving record name from aSub input/output fields
Hi all,
Quick question this time. I was wondering if there was a way to retrieve the name of the record referenced in an OUTLINK/INLINK field such as INPA, OUTA, etc. in the aSub routine.
For instance, suppose I had an aSub record such as the following.
record(aSub, “example”)
                field(SNAM, “func”)
                field(INPA,   “rec_in_inpa”)
I would like to be able to print the name of the record in INPA within “func”.
                char *rec_name = prec->____;
                return 0;
Andy
Purple ribbon awareness
Re: Retrieving record name from aSub input/output fields Michael Davidsaver via Tech-talk
Re: Retrieving record name from aSub input/output fields Andrew Johnson via Tech-talk
Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
Prev: RE: PINI field not working with modbus Mark Rivers via Tech-talk
Next: PVA and Docker on Mac Juan F. Esteban Müller via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Retrieving record name from aSub input/output fields Wang, Andrew via Tech-talk
Next: Re: Retrieving record name from aSub input/output fields Michael Davidsaver via Tech-talk
