1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Issue with RULES_BUILD of seq 2.2.9
From: NICOLE Remi via Tech-talk <[email protected]>
Date: Thu, 11 Aug 2022 12:19:27 +0000
Hello all!
I recently tried to upgrade our seq package in our internal build tool
from seq 2.2.6 to seq 2.2.9, and came across an issue.
If I understood correctly, the 2.2.9 version introduces a more modern
RULES_SNCSEQ, which gets installed through CFG, and the old RULES_BUILD
sources the new RULES_SNCSEQ for backwards compatibility.
The way that I'm building it, is by using INSTALL_LOCATION to install
seq in a separate directory, and then drop the original source code.
The issue that I have is that RULES_BUILD and RULES_SNCSEQ are both in
configure/ in the source code, but in the target directory, RULES_BUILD
gets installed in the target configure/, but RULES_SNCSEQ gets
installed under cfg/.
The way RULES_BUILD tries to include RULES_SNCSEQ is by including in
the same directory, which is not the case when using INSTALL_LOCATION.
My current ugly workaround is to have this in RULES_BUILD:
-include $(dir $(lastword $(MAKEFILE_LIST)))/RULES_SNCSEQ
-include $(TOP)/cfg/RULES_SNCSEQ
Which is not optimal since it will silently do nothing if no file is
found.
If I try to always include it from cfg/, the build of seq fails to find
the file, as it does not get installed early enough.
Is it possible to place RULES_SNCSEQ directly under cfg/ in the
upstream source?
Kind regards
Rémi NICOLE <[email protected]>
CEA/DRF/IRFU/DIS/LDISC
Re: Issue with RULES_BUILD of seq 2.2.9 Ralph Lange via Tech-talk
Re: Issue with RULES_BUILD of seq 2.2.9 Han Lee via Tech-talk
Prev: Re: pypva, PvObject and NTTable Kuldeep Joshi via Tech-talk
Next: Rocky Linux 8 RPMs Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: pypva, PvObject and NTTable Veseli, Sinisa via Tech-talk
Next: Re: Issue with RULES_BUILD of seq 2.2.9 Ralph Lange via Tech-talk
