1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: How to input TIME field values in aSub record types?
From: Amin Hosseini Nejad via Tech-talk <[email protected]>
Date: Mon, 15 Aug 2022 06:08:42 +0000
Hello,
I need to have an array of TIME field values of a PV as an input to an aSub record, but since the input type should be one of the data type listed on menuFtype, I do know how to do so, so I would appreciate it if anyone could direct me on that.
As an idea, I thought of getting the TIME field values as string and then, filling the array using circular buffer algorithm in a compress record, and then, imputing the array to the aSub record as a string array, and in the c++ subroutine, converting the TIME field values to epicsTime, but the challenge I am facing is that the TIME field value is of NTP format, and I do not know what format specifier, not listed in strftime function, I can use to expand the fractional part of the time, and I can just not ignore that part of the TIME value. I know I can set up my format specifier using  boost::date_time library and its time_facet in my c++ subroutine, but I still have the problem getting the fractional part using stringin record type described in below link:
https://epics.anl.gov/tech-talk/2016/msg01039.php
Thank you in advance and will be looking forward to hearing back from you soon.
Amin
Re: How to input TIME field values in aSub record types? Andrew Johnson via Tech-talk
Prev: Re: Makefile rule differences with base 3.14 vs 3.15+ in ADCore build with pvi Michael Davidsaver via Tech-talk
Next: Re: CSS spinner and text box instant write Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: CSS spinner and text box instant write Kasemir, Kay via Tech-talk
Next: Re: How to input TIME field values in aSub record types? Andrew Johnson via Tech-talk
