On 8/31/22 07:40, Mark Rivers via Tech-talk wrote:
If I change the Makefile to use DB rather than DB_INSTALLS for the first file, it works fine:
I mostly put .proto files in DB=
It seems like DB_INSTALLS works if the file has a path, but does not work if the file is in the current directory?
I've only ever used DB_INSTALLS= to pull in external files
to get a more self-contained IOC application build.
eg. situations like:
ifneq (,$(AUTOSAVE))
DB_INSTALLS += $(AUTOSAVE)/db/save_restoreStatus.db
endif
makes a copy of save_restoreStatus.db in the local $(TOP)/db
so that my st.cmd won't be effected by subsequent changes
under $(AUTOSAVE).
- Problem with DB_INSTALLS in Makefile Mark Rivers via Tech-talk
Re: Problem with DB_INSTALLS in Makefile Andrew Johnson via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
