Hi Mark,
On 8/31/22 9:40 AM, Mark Rivers via
Tech-talk wrote:
I just tested the template file generation
in asyn with this command:
/home/epics/devel/asyn/bin/linux-x86_64/makeSupport.pl
-t streamSCPI test4
This is the Makefile it generated:
corvette:~/scratch/test4/test4Sup>more
Makefile
TOP=..
include $(TOP)/configure/CONFIG
# Install .dbd and .db files
DB_INSTALLS += devtest4.db
DB_INSTALLS +=
$(TOP)/test4Sup/devtest4.proto
include $(TOP)/configure/RULES
The Makefile looks OK to me. I am not sure why the
proto file has an explicit path, and the .db file did not,
since they are in the same directory.
The makeSupport.pl script is just copying the template files
provided by Asyn and substituting macros.
makeSupport/streamSCPI/_Name_Sup/Makefile template exactly matches
the above. It looks like Janet made a change between Base-3.14.9 and
3.14.10 that modified the DB_INSTALLS rule to do what it does now.
It seems like DB_INSTALLS works if the file has a
path, but does not work if the file is in the current
directory?
As Michael explained, DB_INSTALLS is now used for installing local
copies of files from other modules, whereas DB is used for
installing files that come from this source directory. You may be
able to use
DB_INSTALLS
+= ../devtest4.db
instead of DB, but that merely complicates the Makefile.
You'll need to adjust the template files in Asyn as appropriate.
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Problem with DB_INSTALLS in Makefile Mark Rivers via Tech-talk
Re: Problem with DB_INSTALLS in Makefile Michael Davidsaver via Tech-talk
Re: EPICS on ESP32 Eric Norum via Tech-talk
<2022>
2025
2026
RE: Problem with DB_INSTALLS in Makefile Mark Rivers via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
