1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Problem with DB_INSTALLS in Makefile
Date: Wed, 31 Aug 2022 14:40:40 +0000
I just tested the template file generation in asyn with this command:
/home/epics/devel/asyn/bin/linux-x86_64/makeSupport.pl -t streamSCPI test4
It worked fine, and generated this test4/test4Sup directory:
corvette:~/scratch/test4/test4Sup>ls -l
total 12
-rw-rw-r-- 1 epics domain users  256 Aug 31 08:44 Makefile
-rw-rw-r-- 1 epics domain users 2032 Aug 31 08:07 devtest4.db
-rw-rw-r-- 1 epics domain users  190 Aug 31 08:07 devtest4.proto
This is the Makefile it generated:
corvette:~/scratch/test4/test4Sup>more Makefile
TOP=..
include $(TOP)/configure/CONFIG
# Install .dbd and .db files
DB_INSTALLS += devtest4.db
DB_INSTALLS += $(TOP)/test4Sup/devtest4.proto
include $(TOP)/configure/RULES
The Makefile looks OK to me.  I am not sure why the proto file has an explicit path, and the .db file did not, since they are in the same directory.
However, when I run it I get the following error:
corvette:~/scratch/test4/test4Sup>make
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[1]: Entering directory `/home/epics/scratch/test4/test4Sup/O.linux-x86_64'
make[1]: *** No rule to make target `devtest4.db', needed by `../../db/devtest4.db'.  Stop.
make[1]: Leaving directory `/home/epics/scratch/test4/test4Sup/O.linux-x86_64'
make: *** [install.linux-x86_64] Error 2
If I change the Makefile to use DB rather than DB_INSTALLS for the first file, it works fine:
TOP=..
DB += devtest4.db
perl -CSD /usr/local/epics-devel/base-7.0.6.1/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /usr/local/epics-devel/base-7.0.6.1/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
mkdir -p O.Common
Installing ../../db/devtest4.db
mkdir ../../db
Installing ../../db/devtest4.proto
make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. \
    T_A=vxWorks-ppc32 install
make[1]: Entering directory `/home/epics/scratch/test4/test4Sup/O.vxWorks-ppc32'
make[1]: Nothing to be done for `install'.
make[1]: Leaving directory `/home/epics/scratch/test4/test4Sup/O.vxWorks-ppc32'
It seems like DB_INSTALLS works if the file has a path, but does not work if the file is in the current directory?
This is base 7.0.6.1.
Re: Problem with DB_INSTALLS in Makefile Michael Davidsaver via Tech-talk
Re: Problem with DB_INSTALLS in Makefile Andrew Johnson via Tech-talk
Prev: Building with INSTALL_PATH= Dudley, David via Tech-talk
Next: Re: Problem with DB_INSTALLS in Makefile Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Building with INSTALL_PATH= Andrew Johnson via Tech-talk
