1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Epics archiver appliance freezing
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Thu, 1 Sep 2022 06:28:44 +0000
Hello All,
I am having an issue with the epics archiver appliance and was wondering else has seen this behavior.  The main website will load fine for a little while and I am able to search PVs and get return status.  Then after running some PVs through CS studio, I will try to search again in the archiver web page and it just freezes on the return request.  The page doesn’t crash but it just will not return anything status wise about the PV search.  It only started happening recently and wondering if something got added to the archiving that is causing some type of freeze up? I have checked the drive space, network, IOCs, restarting hardware, it seems to always freeze now.
Is there a way an easy way to go into the sql database and see what the total list of PV the search uses (I think I remember that is where it stores the list details)?
Is there a specific log to look into to see the freeze up, most of the logs I’ve checked out have tons of information but not sure what I am searching for as the culprit.
I am close to trying to reinstall and start fresh again but would be nice to know why it’s doing it.
Thanks
Adam
Prev: Re: asyn build fail Siddons, David via Tech-talk
Next: Re: Epics archiver appliance freezing Shankar, Murali via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: asyn build fail Andrew Johnson via Tech-talk
