1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: asyn build fail
From: Andrew Johnson via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 1 Sep 2022 10:05:12 -0500
It is possible for most recent compiler versions to test for the presence of a library header file, and we use this in the next Base release to autodetect the GNU Readline setting to use by asking the C pre-processor to look for the header file, and define a build-system setting indicating how to configure this target (the user can override that if they want though). See here for the C file we use.
The Asyn module could do this for the RPC library, and should also publish one or more files in its cfg/ install directory telling downstream modules what libraries the IOCs that use it should be linked with (which may be different for each target architecture since that depends on the whether the target uses sunrpc or tirpc) — it's a pain to have to configure downstream modules and IOCs for the TIRPC setting as well as Asyn itself, and this avoids having to do that.
- Andrew
On 8/31/22 6:06 PM, Siddons, David via Tech-talk wrote:
Hi Yong,
  Yes, but this wonderful EPICS community always comes through with the solution in record time 🙂
Pete.
Sent: Wednesday, August 31, 2022 7:02 PM
To: Li, Ji <[email protected]>; [email protected] <[email protected]>; Siddons, David <[email protected]>
Hi Pete, this happened to many people, including me. I guess this will continue trip other people. See this report: https://github.com/epics-modules/asyn/issues/95.
It would be nice if this kind of compile error could be fixed in future asyn release.
Cheers,
Yong
From: Tech-talk <[email protected]> on behalf of Li, Ji via Tech-talk <[email protected]>
Date: Wednesday, August 31, 2022 at 3:09 PM
To: [email protected] <[email protected]>, Siddons, David <[email protected]>
Hi Pete,
You can uncomment this line in CONFIG_SITE of asyn:
# TIRPC=yes
Then the compiler should be able to look for this file in /usr/include/tirpc/.
Best,
-Ji
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Wednesday, August 31, 2022 14:56
Subject: asyn build fail
I am provisioning a new machine (Ubuntu 22.04), and have installed and built base-3.15.9. I'm now installing synApps, and the build failed  when building asyn, see below:
make[3]: Entering directory '/home/peter/epics/synApps/support/asyn-R4-42/asyn/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API  -D_X86_64_ -DUNIX  -Dlinux     -O3   -Wall    -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC  -mtune=generic    -m64 -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc -I../../include/os/Linux -I../../include      -I/home/peter/epics/synApps/support/ipac-2-16/include   -I/home/peter/epics/synApps/support/seq-2-2-9/include -I/home/peter/epics/base-3.15.9/include/compiler/gcc -I/home/peter/epics/base-3.15.9/include/os/Linux -I/home/peter/epics/base-3.15.9/include        -c vxi11core_xdr.c
In file included from vxi11core_xdr.c:6:
vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory
    9 | #include <rpc/rpc.h>
compilation terminated.
The file /usr/include/rpc/rpc.h does not exist. There is a file /usr/include/tirpc/rpc/rpc.h. Should I simply copy the files into /usr/include? Or edit the offending source files to point to these new locations?
Pete.
Complexity comes for free, Simplicity you have to work for.
asyn build fail Siddons, David via Tech-talk
Re: asyn build fail Li, Ji via Tech-talk
Re: asyn build fail Hu, Yong via Tech-talk
Re: asyn build fail Siddons, David via Tech-talk
Prev: Re: Epics archiver appliance freezing Shankar, Murali via Tech-talk
Next: RE: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: asyn build fail Siddons, David via Tech-talk
Next: Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
