Hi Yong,
Yes, but this wonderful EPICS community always comes through with the solution in record time
Pete.
Hi Pete, this happened to many people, including me. I guess this will continue trip other people. See this report:
https://github.com/epics-modules/asyn/issues/95.
It would be nice if this kind of compile error could be fixed in future asyn release.
Cheers,
Yong
You can uncomment this line in CONFIG_SITE of asyn:
Then the compiler should be able to look for this file in /usr/include/tirpc/.
I am provisioning a new machine (Ubuntu 22.04), and have installed and built base-3.15.9. I'm now installing synApps, and the build failed when building asyn, see below:
make[3]: Entering directory '/home/peter/epics/synApps/support/asyn-R4-42/asyn/O.linux-x86_64'
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DBUILDING_asyn_API -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -DUSE_TYPED_RSET -DUSE_TYPED_DSET -DUSE_TYPED_DRVET
-DHAVE_LSREC -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I../../asyn/drvAsynSerial/os/Linux -I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous
-I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/asynPortClient -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/compiler/gcc
-I../../include/os/Linux -I../../include -I/home/peter/epics/synApps/support/ipac-2-16/include -I/home/peter/epics/synApps/support/seq-2-2-9/include -I/home/peter/epics/base-3.15.9/include/compiler/gcc -I/home/peter/epics/base-3.15.9/include/os/Linux
-I/home/peter/epics/base-3.15.9/include -c vxi11core_xdr.c
In file included from vxi11core_xdr.c:6:
vxi11core.h:9:10: fatal error: rpc/rpc.h: No such file or directory
The file /usr/include/rpc/rpc.h does not exist. There is a file /usr/include/tirpc/rpc/rpc.h. Should I simply copy the files into /usr/include? Or edit the offending source files to point to these new locations?
- Re: asyn build fail Andrew Johnson via Tech-talk
- asyn build fail Siddons, David via Tech-talk
- Re: asyn build fail Li, Ji via Tech-talk
- Re: asyn build fail Hu, Yong via Tech-talk
Epics archiver appliance freezing Manoussakis, Adamandios via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
