> On that related note, I also have a separate datum that I want to put into a time series. At
present I write that value out on its own NDArray Address. Do I then use that address in the NDTimeSeriesConfigure line later?
Yes, that is correct. You can actually put more than 1 datum in an array, which is what NDPluginStats does. This is documented here:
It looks like that would solve the problem. Part of my reason for asking is that I am trying to get a better sense of how the various areaDetector plugins work and fit together.
On that related note, I also have a separate datum that I want to put into a time series. At present I write that value out on its own NDArray Address. Do I then use that address in the NDTimeSeriesConfigure line later?
> I would like to be able to do the time series of the X and Y centroids.
The time series of the X and Y centroids is easy. This is a screen shot of the NDPluginStats screen.
In the Centroid section there is a menu labeled "Time series plots". Simply select "Centroid X" and you will see a plot like this:
Maybe I am not understanding the question?
For a project, I successfully have NDPluginStats computing the profile and centroid of an image. I would like to be able to do the time series of the X and Y centroids. I have been looking at the synApps QuadEM as a starting point, and it seems that in QuadEM
the positions are output on specific NDArray Addresses, while that is not the case with NDPluginStats. Is there some way to select only the centroids of the NDPluginStats to put into a time series?
Iain Marcuson
Software Engineer, Sydor Technologies
585.278.1168 |
www.SydorTechnologies.com
Skype:
[email protected]
This message has been scanned for malware by Forcepoint.
www.forcepoint.com
Click
here to report this email as spam.
- Getting a time series of some NDPluginStats Iain Marcuson via Tech-talk
- Re: Getting a time series of some NDPluginStats Mark Rivers via Tech-talk
- RE: Getting a time series of some NDPluginStats Iain Marcuson via Tech-talk
RE: Getting a time series of some NDPluginStats Pearson, Matthew via Tech-talk
EPICS 7.0.7 Released Andrew Johnson via Tech-talk
<2022>
2025
2026
Clog 2.0 released Wang, Lin via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
