1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: DMOV flag problem with soft motor
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: "Celcer Tine (PSI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 28 Sep 2022 17:17:09 +0200
Hej Tine,
this smells a little bit like the
"done before even started" phenomenon.
The controller is commanded to move, execute is set, but it hasn't
started yet.
If this the case: We have added the
"waitNumPollsBeforeReady" feature, in the EPICS driver.
This may help:
<https://github.com/EuropeanSpallationSource/m-epics-ethercatmc/blob/master/ethercatmcApp/src/ethercatmcAxis.cpp>
(And today, we are using a different approach, with a bi-directional state machine inside the PLC-code. But that is a longer story)
BR
/Torsten
On 2022-09-28 16:57, Celcer Tine (PSI) via Tech-talk wrote:
addendum: The delay is actually on the TwinCAT PLC between issuing the EXECUTE command and the time of setting the DONE flag to “ACTIVE”.
Dr. Tine Celcer
Controls Section
Group Leader Integration and Support – Photon Science
Group Leader a.i. Integration and Support – Large Research Facilities
WBGB/013
Phone: +41 56 310 46 29
[email protected] <mailto:[email protected]>
Paul Scherrer Institut
CH-5232 Villigen PSI
On 28 Sep 2022, at 16:32, Celcer Tine (PSI) <[email protected] <mailto:[email protected]>> wrote:
Hi all,
We use a Beckhoff TwinCAT controller to move 3 independent axes, and it is integrated into EPICS via the s7 driver. Now I am trying to add the soft motor record support on top of that. Everything works fine except for a problem with the .DMOV field. The .DINP filed is linked to the DONE flag of the TwinCAT controller.
When initiating the motion from “s7” EPICS PVs, the soft motor DMOV field behaves as expected, however when the move is initiated by the motor record I get the 1/0/1/0/1 pulse form the DMOV instead of the desired 1/0/1 (of course any user script monitoring the DMOV would capture that additional pulse). I notice that the first 1/0/1 pulse happens before the DONE flag changes to 0, and the remaining /0/1 part is in accordance with the processing of the DONE flag (as expected via ca link).
I suspect that the reason is in the way the Twincat motion is implemented - one has to set the position first and then execute the “GO” command. I handle this with a sequence record that is linked to the OUT filed of the motor record. Could the fact that there is a delay between the time of writing to the motor record .VAL field and the time that the “GO” command is issued on the PLC and the DONE flag processes, cause the initial 1/0/1 pulse on the motor record .DMOV field (thinking there is no move - analog to sending it to the current position)?
And if this is the case, is there a “timeout” I could set for that? Or any other ideas how to overcome this issue?
record(motor, "$(P):$(AXIS)") {
  field(DESC, "$(AXIS) soft motor")
  field(DTYP, "Soft Channel")
  field(OUT,  "$(P):$(AXIS)_SETANDGO PP")
  field(RDBL, "$(P):$(AXIS)_RBVCALC NPP")
  field(MRES, "1")
  field(RRES, "1")
  field(URIP, "Yes")
  field(PREC, "2")
  field(EGU,  "mm")
  field(TWV,  "1")
  field(DINP, "$(P):$(AXIS)_DONE NPP")
  field(RTRY, "0")
  field(NTM,  "NO")
record(seq, "$(P):$(AXIS)_SETANDGO") {
  field(DOL1, "$(P):$(AXIS).DVAL")
  field(LNK1, "$(P):$(AXIS)_SETPOS PP")
  field(DOL2, "1")
  field(LNK2, "$(P):$(AXIS)_EXECUTE PP")
Tine
Dr. Tine Celcer
Controls Section
WBGB/013
Re: DMOV flag problem with soft motor Kevin Peterson via Tech-talk
DMOV flag problem with soft motor Celcer Tine (PSI) via Tech-talk
Re: DMOV flag problem with soft motor Celcer Tine (PSI) via Tech-talk
Prev: Re: DMOV flag problem with soft motor Celcer Tine (PSI) via Tech-talk
Next: Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: DMOV flag problem with soft motor Kevin Peterson via Tech-talk
