The motor record sets the DMOV to 0 when the soft motor's target
position changes. After that it looks at the PV specified in the DINP
field and expects the value to be 0 until motion is done. If there is a
delay in updating the DINP PV, the unwanted extra DMOV transition occurs.
I believe you can work around the problem by doing the following to
ensure the DINP PV is moving *before* the move is initiated:
record(motor, "$(P):$(AXIS)") {
field(DESC, "$(AXIS) soft motor")
field(DTYP, "Soft Channel")
field(OUT, "$(P):$(AXIS)_SETANDGO PP")
field(RDBL, "$(P):$(AXIS)_RBVCALC NPP")
field(MRES, "1")
field(RRES, "1")
field(URIP, "Yes")
field(PREC, "2")
field(EGU, "mm")
field(TWV, "1")
field(DINP, "$(P):$(AXIS)_DMOV NPP")
field(RTRY, "0")
field(NTM, "NO")
record(seq, "$(P):$(AXIS)_SETANDGO") {
field(DOL1, "1")
field(LNK1, "$(P):$(AXIS)_MOVING PP")
field(DOL2, "$(P):$(AXIS).DVAL")
field(LNK2, "$(P):$(AXIS)_SETPOS PP")
field(DOL3, "1")
field(LNK3, "$(P):$(AXIS)_EXECUTE PP")
record(bo, "$(P):$(AXIS)_MOVING") {
field(ONAM, "Done")
field(ZNAM, "Moving")
record(calcout, "$(P):$(AXIS)_DMOV") {
field(INPA, "$(P):$(AXIS)_MOVING CP")
field(CALC, "!A")
record(calcout, "$(P):$(AXIS)_RESET") {
field(INPA, "$(P):$(AXIS)_DONE CP")
field(CALC, "A")
field(OOPT, "Transition to Non-zero")
field(DOPT, "Use OCAL")
field(OCAL, "!A")
field(OUT, "$(P):$(AXIS)_MOVING")
I haven't tested it, though, so it might not work as advertised.
Kevin
On 9/28/22 10:17, Torsten Bögershausen via Tech-talk wrote:
this smells a little bit like the
"done before even started" phenomenon.
The controller is commanded to move, execute is set, but it hasn't
started yet.
- DMOV flag problem with soft motor Celcer Tine (PSI) via Tech-talk
- Re: DMOV flag problem with soft motor Celcer Tine (PSI) via Tech-talk
- Re: DMOV flag problem with soft motor Torsten Bögershausen via Tech-talk
Re: asynMotorController weird behavior when using any read/write interface mask Mark Rivers via Tech-talk
Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Marco A. Barra Montevechi Filho via Tech-talk
<2022>
2025
2026
Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
<2022>
2025
2026
