1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values.
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Cc: Augusto Yoshio Horita <[email protected]>
Date: Thu, 29 Sep 2022 17:43:07 +0000
Hello all. We were having problems with Pmac 2-5-16 here at LNLS. The problem was solved by Augusto Horita (in copy), but the behavior was weird and we though maybe someone here knows why it is like that or maybe reporting it in tech-talk would be useful for other people.
The IOC was compiled with EPICS base 3.15.6.
The particular instance that we were having trouble with had a set of axis in the PVs such as:
BL:H:PB02:CS1:m1
the axis was configured with
pmacSetCoordStepsPerUnit("$(PPMAC_CS1_PORT)", 1, 1000)
and its MRES was set to 10E-3.
When initialized, the IOC sometimes showed the right values for .RBV and .VAL fields, but sometimes showed values 10 times bigger than what should be. Sometimes the *10 factor was only in .RBV, sometimes only in .VAL and sometimes in both.
Augusto suspected this was due to failure in pmacSetCoordStepsPerUnit since the default scale factor is 10000 (ten times bigger than what we were using). So we suspected that the function was failing for whatever reason and defaulting the scale factor to 10000 while MRES remained in 10E-3. Indeed, changing MRES to 10E-4 and
 to
pmacSetCoordStepsPerUnit("$(PPMAC_CS1_PORT)", 1, 10000)
Solved the problem.
In the middle of the debug process, we struggled to find any error message about the suspected failure in pmacSetCoordStepsPerUnit.
Is this absence of error message intentional? Is there a particular debug method we should have used?
Has this been reported before?
Thanks for the attention. Best regards,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Torsten Bögershausen via Tech-talk
Prev: Re: DMOV flag problem with soft motor Kevin Peterson via Tech-talk
Next: Re: CA library usage problem Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: CA library usage problem Andrew Johnson via Tech-talk
Next: Re: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Torsten Bögershausen via Tech-talk
