1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: CA library usage problem
From: Andrew Johnson via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>, [email protected]
Date: Thu, 29 Sep 2022 12:45:07 -0500
Hi Jörn,
On 9/29/22 7:49 AM, Jörn Dreyer via Tech-talk wrote:
i guess I have a misunderstanding how to use the user callback functions
together with a subscription to a PV variable.
In my userfunc the value of arg.status is always 1 which evaluates to a
ca_message of "Normal successful completion". But the documentation say's to
check against ECA_NORMAL witch is 0.
What am I doing wrong here.
Actually the macro ECA_NORMAL expands to the value 1, so arg.status == ECA_NORMAL will evaluate to true in your userfunc as described above. The status macros defined in caerr.h are somewhat confusing as they are actually a bitmask — the bottom 3 bits are a severity code, and the severity code CA_K_SUCCESS has the value 1. I suspect this may have been done to avoid using a status value of 0 which could then be used to detect the absence of a status value, although I doubt if anyone uses it like that now.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
CA library usage problem Jörn Dreyer via Tech-talk
Prev: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: CA library usage problem Jörn Dreyer via Tech-talk
Next: Suspicious behavior of Pmac 2-5-16 IOC. .RBV and .VAL showing wrong values. Marco A. Barra Montevechi Filho via Tech-talk
