1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: EPICS 3.15.6 base with vxWorks-6.9 compile error for the ppc32
From: "Wang, Lin via Tech-talk" <[email protected]>
To: whitetiger1123 <[email protected]>
Date: Fri, 7 Oct 2022 14:15:55 +0800 (GMT+08:00)
Hello,
For vxWorks installation, the "gnu" directory is below "WindRiver" rather than "WindRiver/vxworks-6.9", so the WIND_BASE in CONFIG_SITE.Common.vxWorksCommon should be,
WIND_BASE = /home/abcd/WindRiver
rather than WIND_BASE = /home/abcd/WindRiver/vxworks-6.9
Lin
-----Original Messages-----
From:"whitetiger1123 via Tech-talk" <[email protected]>
Sent Time:2022-10-07 09:34:25 (Friday)
Cc:
Subject: [SPAM] EPICS 3.15.6 base with vxWorks-6.9 compile error for the ppc32
I encounter an error while building an EPICS 3.15.6 base with vxWorks-6.9 for the case of CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc32, see error messages below.
I changed each PATH
  1. /base-3.15.6/configure/CONFIG_SITE
    • CROSS_COMPILER_TARGET_ARCHES : vxWorks-ppc32
  2. Base-3.15.6/configure/os/CONFIG_SITE.Common.vxWorksCommon
    • VXWORKS_VERSION = 6.9
    • WIND_BASE = /home/abcd/WindRiver/vxworks-6.9
Like this.
And then make the epics_base-3.15.6, it shows me this kind of make error:
make[3]: /home/abcd/WindRiver/vxworks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc: Command not found
make[3]: *** [vxComLibrary.o] Error 127
make[3]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src/libCom/O.vxWorks-ppc32'
make[2]: *** [install.vxWorks-ppc32] Error 2
make[2]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src'
make: *** [src.install] Error 2
I’d like to know how can I fix this error
Thank you.
EPICS 3.15.6 base with vxWorks-6.9 compile error for the ppc32 whitetiger1123 via Tech-talk
Prev: EPICS 3.15.6 base with vxWorks-6.9 compile error for the ppc32 whitetiger1123 via Tech-talk
Next: Re: point pcaspy to EPICS 7 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Example asynMotorController Abdalla Ahmad via Tech-talk
