I encounter an error while building an EPICS 3.15.6 base with vxWorks-6.9 for the case of CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc32, see error messages below.
I changed each PATH
- /base-3.15.6/configure/CONFIG_SITE
- CROSS_COMPILER_TARGET_ARCHES : vxWorks-ppc32
- Base-3.15.6/configure/os/CONFIG_SITE.Common.vxWorksCommon
- VXWORKS_VERSION = 6.9
- WIND_BASE = /home/abcd/WindRiver/vxworks-6.9
Like this.
And then make the epics_base-3.15.6, it shows me this kind of make error:
make[3]: /home/abcd/WindRiver/vxworks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc: Command not found
make[3]: *** [vxComLibrary.o] Error 127
make[3]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src/libCom/O.vxWorks-ppc32'
make[2]: *** [install.vxWorks-ppc32] Error 2
make[2]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/home/abcd/EPICS/base-3.15.6/src'
make: *** [src.install] Error 2
I’d like to know how can I fix this error
Thank you.
