1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: point pcaspy to EPICS 7
From: "Wang Xiaoqiang \(PSI\) via Tech-talk" <[email protected]>
To: "Gregory, Ray" <[email protected]>
Date: Fri, 7 Oct 2022 17:15:33 +0000
Hi Ray,
I guess so. Most binary build of pcaspy are built against epics 3.
But in regards of PCAS module, no big differences since epics 3.
It depends on where the binary version is from. It is very likely
to have the epics libraries statically linked, which is the default.
Check it with ldd command,
$ ldd _cas.cpython-310-x86_64-linux-gnu.so
If no libCom in the output then it is statically linked.
Best
Xiaoqiang
> On 7 Oct 2022, at 18:35, Gregory, Ray <[email protected]> wrote:
> Hi Xiaoqiang,
> Thanks for the info.
> Does this mean that I would need to build pcaspy from source to get it to use EPICS 7?
> And that the binary version of pcaspy that I installed previously is using the version of EPICS I was using (what EPICS_BASE pointed to) when I installed it?
> Thank you,
> Ray
> Ray Gregory
> Oak Ridge National Laboratory
> -----Original Message-----
> From: Wang Xiaoqiang (PSI) <[email protected]>
> Sent: Friday, October 07, 2022 8:28 AM
> To: Gregory, Ray <[email protected]>
> Cc: [email protected]
> Subject: [EXTERNAL] Re: point pcaspy to EPICS 7
> Hi Ray,
> Here is the steps I use to build PCAS module together with EPICS base.
> hxxps://pcaspy.readthedocs.io/en/latest/installation.html#getting-epics
> Best
> Xiaoqiang
>> On 6 Oct 2022, at 20:19, Gregory, Ray via Tech-talk <[email protected]> wrote:
>> Hi,
>> I have recently built EPICS 7 on a machine that I usually run IOCs with an older version of EPICS (EPICS 3.14.12.6 and EPICS 4.6). Some of these IOCs are Python IOCs that use pcaspy.
>> I would like to create a pcaspy-based IOC on this machine that uses the new EPICS 7 that I have built.
>> How do I point pcaspy to use the new EPICS 7?
>> Thanks,
>> Ray
>> Ray Gregory
point pcaspy to EPICS 7 Gregory, Ray via Tech-talk
Re: point pcaspy to EPICS 7 Wang Xiaoqiang (PSI) via Tech-talk
RE: point pcaspy to EPICS 7 Gregory, Ray via Tech-talk
Prev: RE: point pcaspy to EPICS 7 Gregory, Ray via Tech-talk
Next: Re: Exploring EPICS performance/processing limits Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: EPICS 3.15.6 base with vxWorks-6.9 compile error for the ppc32 whitetiger1123 via Tech-talk
