1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: EPICS mrfioc2 and new mtca card EVRTM-300
To: Michael Davidsaver <[email protected]>, GAGET Alexis <[email protected]>
Cc: Žan Pratnemer <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 7 Oct 2022 07:44:19 +0000
Hi Michael, Alexis,
We have been working with the RTM card from MRF for the last year and with the new versions of the mtca EVR card (mTCA-EVR-300U and mTCA-EVR-300RF).
We have found that RTM is working as expected with both of them, but you need an EVR FW that is at least **0F0207** and a corresponding MMC firmware.
You can check with us directly or reach out to Jukka for the correct/latest versions.
We are still testing the RTM functionality with UNIV-IO modules with Delay functionality.
My colleague (Žan Matic Pratnemer) has published (in the last day or so) some pull requests to the official mrfioc2 github repository that should help others with the new HW.
Please take a look and provide comments/guidance on pull requests.
Best regard,
Žiga
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Michael
> Davidsaver via Tech-talk
> Sent: sreda, 05. oktober 2022 18:55
> To: GAGET Alexis <[email protected]>
> Cc: [email protected]
> Subject: Re: EPICS mrfioc2 and new mtca card EVRTM-300
> Caution: This email originated from outside of Cosylab.
> On 9/30/22 09:20, GAGET Alexis via Tech-talk wrote:
> > Dear MRF driver experts,
> > I am doing some test with the quite new card (1 year), mTCA-EVRTM-300.
> For those who don’t know it this is an universal output extender for the
> MTCA-EVR-300 or even apparently for the MTCA-EVM-300.
> I had not heard of a mTCA-EVRTM-300 before, though as I recall there was a
> previous IFB breakout module for early mTCA-EVR-300 cards (there are two
> variants, which both identify as mTCA-EVRTM-300).
> > I have checked the register and Jukka confirmed me that we have to use
> the TBOutput register and RearUniv in the driver seem to correspond.
> Are "TBOutput" and "RearUniv" the names which appear in the MRF
> documentation you have?
> Could you also give the register offsets?
> see also the output register ranges currently understood by mrfioc2:
> https://github.com/epics-
> modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/evrMr
> mApp/src/evrRegMap.h#L232-L253
> > Have I missed something ?
> Probably not.  The mrfioc2 driver may need to be updated with the mapping
> between physical and logical outputs.
> The input/output configuration for the mTCA-EVM-300.  This does list 16 rear
> output ports for the older IFB breakout.  Maybe your card is being mis-
> identfied?
> mApp/src/drvemSetup.cpp#L180-L183
> The software mapping of output register to symbolic name:
> mApp/src/drvem.cpp#L220-L307
> Note that there are some special cases here, including with the mTCA-EVR-
> 300 for the TCLKA and TCLKB GTX registers.
> > Thanks in advance
> > Alexis GAGET
> > CEA Saclay - DRF/Irfu/DIS/LDISC
> > Bâtiment 472 - pièce 105
> > [email protected]<mailto:[email protected]>
> > 01 69 08 95 17
EPICS mrfioc2 and new mtca card EVRTM-300 GAGET Alexis via Tech-talk
Re: EPICS mrfioc2 and new mtca card EVRTM-300 Michael Davidsaver via Tech-talk
Prev: Re: point pcaspy to EPICS 7 Ralph Lange via Tech-talk
Next: Re: mbbo & calcout for drive position management Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: EPICS mrfioc2 and new mtca card EVRTM-300 Michael Davidsaver via Tech-talk
Next: Understanding EPICS DSET-based driver Abdalla Ahmad via Tech-talk
