1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: EPICS mrfioc2 and new mtca card EVRTM-300
From: Michael Davidsaver via Tech-talk <[email protected]>
To: GAGET Alexis <[email protected]>
Date: Wed, 5 Oct 2022 09:54:40 -0700
On 9/30/22 09:20, GAGET Alexis via Tech-talk wrote:
Dear MRF driver experts,
I am doing some test with the quite new card (1 year), mTCA-EVRTM-300. For those who don’t know it this is an universal output extender for the MTCA-EVR-300 or even apparently for the MTCA-EVM-300.
I had not heard of a mTCA-EVRTM-300 before, though as I recall there was
a previous IFB breakout module for early mTCA-EVR-300 cards (there are
two variants, which both identify as mTCA-EVRTM-300).
I have checked the register and Jukka confirmed me that we have to use the TBOutput register and RearUniv in the driver seem to correspond.
Are "TBOutput" and "RearUniv" the names which appear in the MRF
documentation you have?
Could you also give the register offsets?
see also the output register ranges currently understood by mrfioc2:
https://github.com/epics-modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/evrMrmApp/src/evrRegMap.h#L232-L253
Have I missed something ?
Probably not.  The mrfioc2 driver may need to be updated with the
mapping between physical and logical outputs.
The input/output configuration for the mTCA-EVM-300.  This does list 16 rear output
ports for the older IFB breakout.  Maybe your card is being mis-identfied?
https://github.com/epics-modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/evrMrmApp/src/drvemSetup.cpp#L180-L183
The software mapping of output register to symbolic name:
https://github.com/epics-modules/mrfioc2/blob/a8cb48d549b7aae13206cf2d168c6f1cfec2e1c4/evrMrmApp/src/drvem.cpp#L220-L307
Note that there are some special cases here, including with the mTCA-EVR-300
for the TCLKA and TCLKB GTX registers.
Thanks in advance
Alexis GAGET
CEA Saclay - DRF/Irfu/DIS/LDISC
Bâtiment 472 - pièce 105
[email protected]<mailto:[email protected]>
01 69 08 95 17
RE: EPICS mrfioc2 and new mtca card EVRTM-300 Žiga Oven via Tech-talk
EPICS mrfioc2 and new mtca card EVRTM-300 GAGET Alexis via Tech-talk
Prev: Re: Read and Write errors with VME-EVR-300 Andrew Johnson via Tech-talk
Next: EPICS 7 side-by-side with EPICS 3/4 Gregory, Ray via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: EPICS mrfioc2 and new mtca card EVRTM-300 GAGET Alexis via Tech-talk
Next: RE: EPICS mrfioc2 and new mtca card EVRTM-300 Žiga Oven via Tech-talk
