1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: Attocube AMC100
From: "Ivashkevych, Oksana via Tech-talk" <tech-talk at aps.anl.gov>
To: Tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 12 Oct 2022 21:14:21 +0000
Hello,
We have a new Attocube AMC 100 unit.
I found the following communication about support of the new AMC controllers
https://epics.anl.gov/tech-talk/2021/msg01321.php
I built lua, motorScriptMotor within motor, and found st.cmd.Attocube_AMC startup script.
I am getting nullptr error and the core dump.
I have tried using AMC100.lua script (as was suggested in the link above) instead of Attocube_AMC.lua; renamed the port, thinking that some characters could be the culprit, yet I have same error and the core dump.
When I use vmc.lua I do not have the core dump. Just errors.
Thanks
iocScriptMotor]$ ../../bin/linux-x86_64/scriptMotor st.cmd.Attocube_AMC
< envPaths
epicsEnvSet("IOC","iocScriptMotor")
epicsEnvSet("TOP","/epics/devel/support/motor/modules/motorScriptMotor/iocs/scriptMotorIOC")
epicsEnvSet("MOTOR","/epics/devel/support/motor")
epicsEnvSet("ASYN","/epics/devel/support/asyn")
epicsEnvSet("SNCSEQ","/epics/devel/support/seq")
epicsEnvSet("BUSY","/epics/devel/support/busy")
epicsEnvSet("IPAC","/epics/devel/support/ipac")
epicsEnvSet("EPICS_BASE","/epics/devel/epics-base")
epicsEnvSet("SUPPORT","/epics/devel/support")
epicsEnvSet("LUA","/epics/devel/support/lua")
< /epics/common/xf18idb-ioc1-netsetup.cmd
# BEGIN ANSIBLE MANAGED BLOCK
epicsEnvSet("EPICS_CA_AUTO_ADDR_LIST",         "NO")
epicsEnvSet("EPICS_CA_ADDR_LIST",              "10.66.139.255")
epicsEnvSet("EPICS_CAS_AUTO_BEACON_ADDR_LIST", "NO")
epicsEnvSet("EPICS_CAS_BEACON_ADDR_LIST",      "10.66.139.255")
epicsEnvSet("EPICS_CAS_INTF_ADDR_LIST",        "10.66.139.26")
# END ANSIBLE MANAGED BLOCK
dbLoadDatabase("/epics/devel/support/motor/modules/motorScriptMotor/iocs/scriptMotorIOC/dbd/scriptMotor.dbd")
scriptMotor_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("LUA_SCRIPT_PATH", "./scripts")
#epicsEnvSet("IP_ADDRESS", "123.456.789.000")
epicsEnvSet("IP_ADDRESS", "10.66.138.144")
# Connect to virtual motor controller server
drvAsynIPPortConfigure("AMC","10.66.138.144:9090", 0, 0, 0)
#ScriptControllerConfig( "PORT_NAME", num_axes, "lua_script", "PARAMS=")
ScriptControllerConfig("AMC-1", 2, "Attocube_AMC.lua", "PORT=AMC")
scriptMotor: ../../../luaApp/src/luaaa/luaaa.hpp:979: luaaa::LuaClass< <template-parameter-1-1> >::LuaClass(lua_State*, const char*, const luaL_Reg*) [with TCLASS = _apdWrapper; lua_State = lua_State; luaL_Reg = luaL_Reg]: Assertion `klassName == nullptr' failed.
Aborted (core dumped)
Re: Attocube AMC100 Lang, Keenan C. via Tech-talk
Prev: Re: build EPICS IOC on CRIO Carsten Winkler via Tech-talk
Next: Re: Attocube AMC100 Lang, Keenan C. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Prev: Re: Tech-talk Digest, Vol 16, Issue 594 Carsten Winkler via Tech-talk
ANJ, 12 Oct 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
