Another issue I ran into was with the stage enable, on the web view you
can enable or disable a stage. I tried to do this via the
setControlOutput command using the torque enable/disable button and it
did toggle the enable state but when I then read back this state via the
getControlOutput it was flipping from true/false and I still have no
idea why. I did open a case with attocube and if I get an answer I will
post here.
Here is a snippet of the code that gets executed upon a closedLoop state
change.
if(closedLoop) then
local request = {
jsonrpc = "2.0",
method =
"com.attocube.amc.control.setControlOutput",
params = { AXIS, 1 },
id = AXIS,
api = 2 }
send(request)
else
local request = {
jsonrpc = "2.0",
method =
params = { AXIS, 0 },
id = AXIS,
api = 2 }
send(request)
- RE: Attocube AMC100 Ivashkevych, Oksana via Tech-talk
- Attocube AMC100 Ivashkevych, Oksana via Tech-talk
- Re: Attocube AMC100 Lang, Keenan C. via Tech-talk
- Re: Attocube AMC100 Kevin Peterson via Tech-talk
RE: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Freddie Akeroyd - STFC UKRI via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
