1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: P4P usage for the pvget and pvput for the NTTable in Matlab
From: "Kim, Kuktae via Tech-talk" <[email protected]>
Date: Tue, 25 Oct 2022 23:29:13 +0000
Hi all,
I am trying to use the P4P python module (https://mdavidsaver.github.io/p4p/index.html#) in Matlab for EPICS NTTable PVs.
Versions that I use:
Python: 3.8.13
P4P: 4.1.3
Matlab: 2020a
First, I tested pvget and pvput in linux terminal, then moved to python and Matlab for each step. It works without problem for the NTScalar and NTScalarArray types. But I don't know how to implement for NTTable type. I will put more information below.
Python script to run an NTTable PV for the test,
# Python script to generate NTTable
from p4p.nt import NTTable, NTScalar
from p4p.server import Server, ServerOperation
from p4p.server.thread import SharedPV
import numpy as np
class Handler(object):
    """ A handler for dealing with put requests to our test PVs """
    def put(self, pv: SharedPV, op: ServerOperation) -> None:
        """ Called each time a client issues a put operation on the channel using this handler """
        pv.post(op.value())
        op.done()
table_type = NTTable([("name", "s"), ("number", "d")])
table_rows = []
table_rows.append({"name": "device_1", "number": 1.1})
table_rows.append({"name": "device_2", "number": 1.2})
initial_table = table_type.wrap(table_rows)
table_pv = SharedPV(nt=table_type, initial=initial_table, handler=Handler())
server = Server.forever(providers=[{"TEST:TBL": table_pv}])
In the Linux terminal, pvget and pvput work as expected,
$ pvget TEST:TBL
TEST:TBL 2022-10-25 13:36:05.662
    name number
device_1    1.1
device_2    1.2
$ pvput TEST:TBL value.name="[test1, test2]" value.number="[10, 20]"
Old : 2022-10-25 13:36:05.662
    name number
device_1    1.1
device_2    1.2
New : 2022-10-25 14:18:32.990
 name number
test1     10
test2     20
In the Python command line, work fine; but pvget doesn't show a whole table.
>>> from p4p.client.thread import Context
>>> MatP4P = Context('pva')
>>> MatP4P.get('TEST:TBL')
Value(id:epics:nt/NTTable:1.0, Value(['device_1', 'device_2']))     # <== P4P doesn't show whole information such as in linux terminal
>>> MatP4P.put('TEST:TBL', {'value.name':['test1', 'test2'],'value.number':[10,20]})
Value(id:epics:nt/NTTable:1.0, Value(['test1', 'test2']))
In Matlab command line, pvput shows error message. Due to the colon operator.
>> MatP4P = py.p4p.client.thread.Context('pva')
MatP4P =
  Python Context with properties:
       conf: [1×1 py.builtin_function_or_method]
    hurryUp: [1×1 py.builtin_function_or_method]
    <p4p.client.thread.Context object at 0x7f137bbbff40>
ans =
  Python Value with no properties.
    struct "epics:nt/NTTable:1.0" {
        string[] labels = {2}["name", "number"]
        struct {
            string[] name = {2}["device_1", "device_2"]
            double[] number = {2}[1.1, 1.2]
        } value
        string descriptor = ""
        struct "alarm_t" {
            int32_t severity = 0
            int32_t status = 0
            string message = ""
        } alarm
        struct "time_t" {
            int64_t secondsPastEpoch = 1666730165
            int32_t nanoseconds = 662142992
            int32_t userTag = 0
        } timeStamp
>> MatP4P.put('TEST:TBL', {'value.name': ['test1', 'test2'], 'value.number': [10, 20]})
Warning: Colon operands must be real scalars.
Error using  :
For colon operator with char operands, first and last operands must be char.
Does anybody have a similar experience to mine? Any comments or advice will be appreciated. Since my Matlab version is 2020a, I cannot use pyrun or pyrunfile for now. Thank you.
Best regards,
Kuktae
Re: P4P usage for the pvget and pvput for the NTTable in Matlab Michael Davidsaver via Tech-talk
Prev: RE: IOC make failing on a new linux build, Perl checkrelease Manoussakis, Adamandios via Tech-talk
Next: Newport controller ESP302 Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: P4P usage for the pvget and pvput for the NTTable in Matlab Michael Davidsaver via Tech-talk
