1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Missing DLL entry points in PV utils on windows-x64-mingw?
From: Eloise de Castelnau via Tech-talk <[email protected]>
Date: Fri, 28 Oct 2022 00:59:21 +0000
Hello –
I recently installed epics on my windows PC for the first time and am running IOC’s with asyn, stream, calc, and I’m able to use caget and caput for channel access without issue. However, running pvlist within msys causes it to just fail silently, and running the .exe returns these warnings – it seems like a few of the pvinfo/pvdata DLL’s don’t build correctly. The issue originally presented with base 7.0.4, and then I built fresh on 7.0.7 and saw the same issue. Has anyone ever had this issue on mingw? Transcription of one of the errors [ it opens a myriad of similar dialogs referencing missing entry points in pv****.dll files but I’ve just copied one of them since I don’t imagine the specific entry points are at issue] in case the image doesn’t carry through:
“pvlist.exe – Entry Point Not Found
The procedure entry point _ZNSt7__cxx1118basic_stringstreamlcSt11char_traitslcEsalcEEC1Ev could not be located in the dynamic link library C:\msys64\home\Eloise\base-7.0.7\bin\windows-x64-mingw\pvData.dll”
Thanks!
Eloise de Castelnau
Re: Missing DLL entry points in PV utils on windows-x64-mingw? Michael Davidsaver via Tech-talk
Prev: Re: P4P usage for the pvget and pvput for the NTTable in Matlab Kim, Kuktae via Tech-talk
Next: Re: Attocube AMC100 Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: ADPlugin for average of images Mark Rivers via Tech-talk
Next: Re: Missing DLL entry points in PV utils on windows-x64-mingw? Michael Davidsaver via Tech-talk
