1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: ADEiger : master file not found
From: John Dobbins via Tech-talk <[email protected]>
Date: Tue, 1 Nov 2022 15:27:13 +0000
All,
I have a new problem with my EIGER 4M using ADEiger.  This was working in the past.
ADK version         1.6.6
Driver version      3.4.0
ADCore version    3.12.1
EPICS Base 7.0.3
When I take an image the IOC claims the master file was not found. I am using File Writer.
epics> RestApi::doRequest: timed out
RestApi::put: [param=trigger] request failed
RestApi::getBlob: [sys=7 file=blank15_6_master.h5] file not found
2022/11/01 11:19:37.632 eigerDetector::downloadTask: underlying getFile(blank15_6_master.h5) failed
However, looking in the data folder on the DCU it is there, same or earlier time stampe a s the data file.
e.g.
blank15_6_data_000001.h5      2022-Nov-01 11:19:38    17.1M application/octet-stream
blank15_6_master.h5                   2022-Nov-01 11:19:38    73.8M application/octet-stream
The IOC successfully retrieves the data file.
Any ideas?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Prev: Re: Motor record: motion relative to .RBV Kevin Peterson via Tech-talk
Next: Re: calc type record question Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: RE: calc type record question GAGET Alexis via Tech-talk
Next: NTNDArray with attributes using QSRV group Pas Joao Paulo Martins via Tech-talk
