1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: calc type record question
From: GAGET Alexis via Tech-talk <[email protected]>
To: "Meddage, Varuna" <[email protected]>
Date: Wed, 2 Nov 2022 09:41:57 +0000
To get all information about record I use the "obsolete" following page (that is quite updated anyway ...) : https://wiki-ext.aps.anl.gov/epics/index.php?title=User_Documentation
I haven't found better documentation about it for now:
For your case :
https://epics.anl.gov/base/R7-0/4-docs/calcRecord.html#Expression
CALC can be practical but for limited cases, in your case you can use an "aSub" (C subroutine) or imbricated CALC or also ALARM mechanism (the cleaner way in my opinion).
I think using ALARM you can even get a CALC record without any CALC field expression, something like that, the MS means maximized severity, and your calc will take the upper ALARM level. (MINOR if one of the INP is beyond its limits) (https://docs.epics-controls.org/en/latest/guides/EPICS_Process_Database_Concepts.html)
record(ai, "$(detector)_wib$(crate)0$(wib)/vcc") {
    field(HIGH, "5.2")
    field(LOW,  "4.6")
    field(HSV, "MINOR")
    field(LSV,  "MINOR")
Etc ...
record(calc,"$(detector)_wib$(crate)0$(wib)/calc")
      field(SCAN,"5 second")
      field(INPA,"$(detector)_wib$(crate)0$(wib)/vcc MS")
      field(INPB,"$(detector)_wib$(crate)0$(wib)/v1 MS")
      field(INPC,"$(detector)_wib$(crate)0$(wib)/v2 MS")
      field(INPD,"$(detector)_wib$(crate)0$(wib)/v3 MS")
      field(INPE,"$(detector)_wib$(crate)0$(wib)/v4 MS")
I haven't tested it, but it should work
Cheers
Alexis GAGET
CEA Saclay - DRF/Irfu/DIS/LDISC
-----Message d'origine-----
De : Tech-talk <[email protected]> De la part de Meddage, Varuna via Tech-talk
Envoyé : mardi 1 novembre 2022 16:08
À : [email protected]
Objet : calc type record question
I have following "calc" type record in one of my .db files.
      field(CALC,"((A>=4.6&&A<=5.2)&&(B>=4.6&&B<=5.2)&&(C>=1.75&&C<=1.80)&&(D>=3.2&&D<=3.4)&&(E>=0.7&&E<=2.0))?1:0")
      field(INPA,"$(detector)_wib$(crate)0$(wib)/vcc")
      field(INPB,"$(detector)_wib$(crate)0$(wib)/v1")
      field(INPC,"$(detector)_wib$(crate)0$(wib)/v2")
      field(INPD,"$(detector)_wib$(crate)0$(wib)/v3")
      field(INPE,"$(detector)_wib$(crate)0$(wib)/v4")
      field(DESC,"")
      field(HIHI,"")
      field(HIGH,"")
      field(LOW,"")
      field(LOLO,"")
      field(MDEL,"-1")
      field(ADEL,"-1")
      field(OOPT,"Every Time")
      field(PREC,"6")
When I run the EPICS, then I get an error message saying "String is too long" complaining about the expression, I inserted inside the "CALC" field in this record. But when I reduced the number of input PVs of this record from 5 to 4 and rewrite the expression inside "CALC" field, then there is no error.
Is there maximum number of input PVs, that I can use inside a "calc" type record ?
Any help to understand this issue is highly appreciated.
Thanks
Varuna Meddage
calc type record question Meddage, Varuna via Tech-talk
Prev: Re: calc type record question Pete Jemian via Tech-talk
Next: Re: Re: [EXTERNAL] phoebus display runtime Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: ADEiger : master file not found John Dobbins via Tech-talk
