1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: NTNDArray with attributes using QSRV group Pas
From: Joao Paulo Martins via Tech-talk <[email protected]>
Date: Wed, 2 Nov 2022 14:04:11 +0000
Hello,
I’m trying to instantiate a NTNDArray with some NTAttributes in my IOC using QSRV group PV definitions, as the example in pva2pva (https://github.com/epics-base/pva2pva/blob/master/iocBoot/iocimagedemo/image.db ).
If I set the database as the following:
record(waveform, "$(P)ArrayData") {
    field(FTVL, "USHORT")
    field(NELM, "262144")
    info(Q:group, {
        "$(N):Array":{
            +id:"epics:nt/NTNDArray:1.0",
            "value":{+type:"any",
                     +channel:"VAL",
                     +trigger:"*"},
            "":{+type:"meta", +channel:"SEVR"}
record(mbbi, "$(P)FOO") {
    info(Q:group, {
        "$(N):Array":{
            "attribute[0].value":{+type:"any", +channel:"VAL"},
            "attribute[0].timeStamp":{+type:"meta", +channel:"TIME"}
the resulting NTNDArray PV will have the following structure in its attribute[0] field:
structure
            structure timeStamp
                alarm_t alarm
                    int severity 0
                    int status 0
                    string message NO_ALARM
                time_t timeStamp
                    long secondsPastEpoch 1667394506
                    int nanoseconds 335496073
                    int userTag 0
            any value
                double  0
The timeStamp values of the top structure are correctly taken from the “ArrayData” record. However, for the “attribute[0]” field, the timestamp values are taken from the “FOO” record, but the structure of the NTAttribute contains two other structures (alarm and timeStamp) inside the “top” timeStamp structure.
The question is: how one can set the “timeStamp” structure of the attribute[] taking the TIME information from a different record than the one used to get the array value?
Thanks in advance!
João Paulo Martins
European Spallation Source ERIC
Re: NTNDArray with attributes using QSRV group Pas Kasemir, Kay via Tech-talk
Re: NTNDArray with attributes using QSRV group Pas Michael Davidsaver via Tech-talk
Prev: Re: Re: [EXTERNAL] phoebus display runtime Kasemir, Kay via Tech-talk
Next: Phoebus and dynamic macros GAGET Alexis via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: ADEiger : master file not found John Dobbins via Tech-talk
Next: Re: NTNDArray with attributes using QSRV group Pas Kasemir, Kay via Tech-talk
