1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: calc type record question
From: "Arnold, Ned D. via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Meddage, Varuna" <[email protected]>, "Kasemir, Kay" <[email protected]>
Date: Tue, 1 Nov 2022 16:46:35 +0000
> Try to simplify your _expression_,
and use spare INP fields to hold constants ... C>=1.75&&C  =>  C>=F&&C   (INPF=1.75)
From: Tech-talk <[email protected]> on behalf of Kasemir, Kay via Tech-talk <[email protected]>
Sent: Tuesday, November 1, 2022 11:13 AM
To: [email protected] <[email protected]>; Meddage, Varuna <[email protected]>
The length of the CALC field is limited something around 80 characters.
Try to simplify your _expression_, for example by removing some parentheses that are good for readability but not strictly necessary.
From: Tech-talk <[email protected]> on behalf of Meddage, Varuna via Tech-talk <[email protected]>
Sent: Tuesday, November 1, 2022 11:08 AM
Subject: [EXTERNAL] calc type record question
I have following "calc" type record in one of my .db files.
record(calc,"$(detector)_wib$(crate)0$(wib)/calc")
      field(SCAN,"5 second")
      field(CALC,"((A>=4.6&&A<=5.2)&&(B>=4.6&&B<=5.2)&&(C>=1.75&&C<=1.80)&&(D>=3.2&&D<=3.4)&&(E>=0.7&&E<=2.0))?1:0")
      field(INPA,"$(detector)_wib$(crate)0$(wib)/vcc")
      field(INPB,"$(detector)_wib$(crate)0$(wib)/v1")
      field(INPC,"$(detector)_wib$(crate)0$(wib)/v2")
      field(INPD,"$(detector)_wib$(crate)0$(wib)/v3")
      field(INPE,"$(detector)_wib$(crate)0$(wib)/v4")
      field(DESC,"")
      field(HIHI,"")
      field(HIGH,"")
      field(LOW,"")
      field(LOLO,"")
      field(MDEL,"-1")
      field(ADEL,"-1")
      field(OOPT,"Every Time")
      field(PREC,"6")
When I run the EPICS, then I get an error message saying "String is too long" complaining about the _expression_, I inserted inside the "CALC" field in this record. But when I reduced the number of input PVs of this record from 5 to 4 and rewrite the _expression_ inside "CALC" field, then there is no error.
Is there maximum number of input PVs, that I can use inside a "calc" type record ?
Any help to understand this issue is highly appreciated.
Thanks
Varuna Meddage
Re: calc type record question Pete Jemian via Tech-talk
calc type record question Meddage, Varuna via Tech-talk
Re: calc type record question Kasemir, Kay via Tech-talk
Prev: Re: calc type record question Meddage, Varuna via Tech-talk
Next: Re: calc type record question Pete Jemian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
