1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Altering motor resolution via MRES field
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>, "[email protected]" <[email protected]>
Cc: SOL <[email protected]>
Date: Fri, 11 Nov 2022 08:32:43 -0600
Marco,
Please run the following command on the ioc shell and share the output for the relevant axis:
  asynReport 1 Hydra1
The info printed by the axis report method is likely to be relevant:
https://github.com/epics-motor/motorMicos/blob/1d643c3c50c7c798a44f2e6d7806721eac8b136c/micosApp/src/SMChydraAxis.cpp#L78-L87
Kevin
On 11/10/22 06:51, Marco A. Barra Montevechi Filho via Tech-talk wrote:
Hello all,
We are using a micosIOC (https://github.com/epics-motor/motorMicos.git <https://github.com/epics-motor/motorMicos.git>) to control an UPR-160 motor: https://www.pi-usa.us/fileadmin/user_upload/pi_us/files/product_datasheets/Air_Bearing_Rotation_Stages_UPR-Air_Family.pdf <https://www.pi-usa.us/fileadmin/user_upload/pi_us/files/product_datasheets/Air_Bearing_Rotation_Stages_UPR-Air_Family.pdf>
According to the motor technical data, its resolution can go down to 0.00004 degrees. The current IOC has a motor with .MRES=0.04 deg, so we cant make movements smaller than this. When i caput MRES to 0.004, i can caput .VAL from 0.1 to 0.105, for example, and the motor will move.
However, although the .RBV shows the movement incrementing 0.005 degrees, the actual observed movement is of 0.05 degrees. In other words: changing the motor MRES to ten times lower makes the motor move ten times more than what is commanded.
We (me and Augusto Horita) also tried using the SMChydraChangeResolution("Hydra1", 1, 0.004) function and leaving MRES as 0.004 in substitutions, but the same behavior was found.
Am i doing something wrong?
Thanks for any help,
Marco
Altering motor resolution via MRES field Marco A. Barra Montevechi Filho via Tech-talk
Prev: Re: vxworks 6.9 mvme6100 ETIMEDOUT(ox3c) error Johnson, Andrew N. via Tech-talk
Next: Re: Altering motor resolution via MRES field Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Altering motor resolution via MRES field Marco A. Barra Montevechi Filho via Tech-talk
