1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Altering motor resolution via MRES field
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>, "[email protected]" <[email protected]>
Cc: SOL <[email protected]>
Date: Fri, 11 Nov 2022 08:51:04 -0600
Marco,
The datasheet for the UPR Air Family lists many optional encoders in the appendix. Which of these encoders is the UPR-160 using?
Kevin
On 11/10/22 06:51, Marco A. Barra Montevechi Filho via Tech-talk wrote:
We are using a micosIOC (https://github.com/epics-motor/motorMicos.git <https://github.com/epics-motor/motorMicos.git>) to control an UPR-160 motor: https://www.pi-usa.us/fileadmin/user_upload/pi_us/files/product_datasheets/Air_Bearing_Rotation_Stages_UPR-Air_Family.pdf <https://www.pi-usa.us/fileadmin/user_upload/pi_us/files/product_datasheets/Air_Bearing_Rotation_Stages_UPR-Air_Family.pdf>
According to the motor technical data, its resolution can go down to 0.00004 degrees. The current IOC has a motor with .MRES=0.04 deg, so we cant make movements smaller than this. When i caput MRES to 0.004, i can caput .VAL from 0.1 to 0.105, for example, and the motor will move.
Altering motor resolution via MRES field Marco A. Barra Montevechi Filho via Tech-talk
Prev: Re: Altering motor resolution via MRES field Kevin Peterson via Tech-talk
Next: vxworks boot problem whitetiger1123 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
