1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: vxworks boot problem
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Sat, 12 Nov 2022 00:16:47 +0900
We are trying to put EPICS on target running vxWorks 6.9.
We could build EPICS Base 3-15-6 for
CROSS_COMPILER_TARGET_ARCHS =vxWorks-ppc32
Now I want to use TFTP to load the vxWorks image at MVME6100
When I am trying to boot and load vxWorks image file but its not loading image and throwing error.
Following is the log of error on boot:
CPU: Motorola MVME6100-0173 – MPC 7457
Version : VxWorks5.5.1
BSP  version : 1.2/5
Creation data : Nov 4 2008, 16:13:29
Press any key to stop auto-boot…
6
[VxWorks Boot]: @
Boot device : geisc0
Unit number : 0
Processor number : 0
Host name : host
File name : /tftpboot/vxWorks
Inet on etherenet : 10.4.49.69:ffffff00
Host inet : 10.4.49.170
Gateway inet : 10.4.49.99
User : test
ftp password : test
flags : 0x0
Attached TCP/IP interface to geisc0.
Attaching network interface lo0… done.
Loading..
Error loading file : errno = 0x3d.
“User: test” is my ubuntu server’s user name and ftp password is ubuntu server’s password.
Is it wrong?
Do I have to check ~/WindRiver/vxworks-6.9/target/config/all/configAll.h file?
This is configAll.h file
/*Default Boot Parameter*/
#define HOST_NAME_DEFAULT “bootHost”  /*host name*/
#define TARGET_NAME_DEFAULT “vxTarget”  /*target name(tn)*/
#define HOST_USER_DEFAULT “target”  /*user (u)*/
#define HOST_PASSWORD_DEFAULT “ “  /*password*/
#define SCRIPT_DEFAULT “ “  /*startup script (s)*/
#define other_default “ “     /*other (0)*/
Are those(“bootHost”, “target”.. etcs) my vxworks boot parameters? I’d like to know how can I set vxworks boot parameters(user , ftp password , host name)
I hope you understand Iam new to the world of RTOS. Casual I’ve been trying to understand them for a week. From there to before he knew nothing of them.
I hope you can help.
Thanks and regards.
Re: vxworks boot problem Andrew Johnson via Tech-talk
Re: vxworks boot problem Wang, Lin via Tech-talk
Prev: Re: Altering motor resolution via MRES field Kevin Peterson via Tech-talk
Next: asynPortDriver nDevices? Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: vxworks boot problem Andrew Johnson via Tech-talk
