1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: booting error on VxWorks
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: "Qadri, S Noor CIV USN NRL (7212) Washington DC (USA)" <noor.qadri at nrl.navy.mil>, "'tech-talk at aps.anl.gov'" <tech-talk at aps.anl.gov>
Date: Fri, 2 Dec 2022 11:27:05 -0600
Hi Noor,
On 12/2/22 9:27 AM, Qadri, S Noor CIV USN NRL (7212) Washington DC (USA) via Tech-talk wrote:
I just came across your post for a booting error with VxWorks (https://epics.anl.gov/tech-talk/2022/msg01756.php), and we just started encountering the same error on our system.
I was wondering if you had any success on resolving this? Any advice or tips would be greatly appreciated!
If I understand right that you're seeing the error message "WARNING:Bootline longer than BOOT_LINE_SIZE (255 bytes). Not saved to NVRAM." then the reason is described in the error message itself — VxWorks CPUs only have a small amount of NVRAM available for storing the boot parameters, and the error is telling you that the parameters you are trying to set need more storage than is available to hold them.
In the case asked on tech-talk the user may have copy/pasted extraneous characters into their parameter strings, and deleting them helped resolve the error for them. If that isn't the case with your settings you will have to work out how to shorten one or more of the file paths in those parameters, until you can get them all to fit. Soft links on the server may be one way to do that.
HTH,
- Andrew
Complexity is free, it's Simplicity that takes work.
booting error on VxWorks Qadri, S Noor CIV USN NRL (7212) Washington DC (USA) via Tech-talk
Prev: booting error on VxWorks Qadri, S Noor CIV USN NRL (7212) Washington DC (USA) via Tech-talk
Next: Re: A simple EPICS driver example for PCI devices using asynPortDriver on Linux Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: motor control css problem whitetiger1123 via Tech-talk
ANJ, 04 Dec 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
