1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Compiling base on Rocky Linux 9
From: Ernesto Paiser via Tech-talk <[email protected]>
To: "Wang Xiaoqiang (PSI)" <[email protected]>
Date: Mon, 5 Dec 2022 11:59:34 -0800
Hi Wang/Andy,
At the end I've installed 3.15.9 without any erros.
I will keep that for the moment until move to 7.
Thank you!
On 12/5/2022 10:39 AM, Wang Xiaoqiang (PSI) wrote:
Try the latest 3.15 release, https://epics.anl.gov/base/R3-15/9.php
On 5 Dec 2022, at 19:27, Ernesto Paiser via Tech-talk <[email protected]> wrote:
Hello guys,
I'm having trouble in compiling EPICS base 3.15.6 in rocky linux 9.
I believe it should be something related to the enforcement rules on gcc compiler.
Someone knows how tho workaround this?
Thank you!!
In file included from ../../../../../../src/ca/legacy/pcas/generic/caServer.cc:21:
../../../../../../src/ca/legacy/pcas/generic/caServerI.h: At global scope:
../../../../../../src/ca/legacy/pcas/generic/caServerI.h:91:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
   91 |     tsDLList < casStrmClient > clientList;
In file included from ../../../../../../src/ca/legacy/pcas/generic/caServerI.h:33,
../../../../../../src/ca/legacy/pcas/generic/ioBlocked.h:43:7: note: declared private here
   43 | class ioBlockedList : private tsDLList<ioBlocked> {
../../../../../../src/ca/legacy/pcas/generic/caServerI.h:92:5: error: ‘class tsDLList<ioBlocked> tsDLList<ioBlocked>::tsDLList’ is private within this context
   92 |     tsDLList < casIntfOS > intfList;
make[2]: *** [../../../../../../configure/RULES_BUILD:236: caServer.o] Error 1
make[2]: Leaving directory '/opt/epics/R3.15.6/base-3.15.6/src/ca/legacy/pcas/build/O.linux-x86_64'
make[1]: *** [../../../../../configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/opt/epics/R3.15.6/base-3.15.6/src/ca/legacy/pcas/build'
make: *** [../../../../configure/RULES_DIRS:84: build.install] Error 2
Ernesto Paiser - Senior Controls Engineer
Sigray, Inc.
5750 Imhoff Dr, Concord, CA 94520
United States
[email protected] <mailto:[email protected]>
+1-650-503-3410
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Sigray, Inc.
United States
+1-650-503-3410
Compiling base on Rocky Linux 9 Ernesto Paiser via Tech-talk
Re: Compiling base on Rocky Linux 9 Wang Xiaoqiang (PSI) via Tech-talk
Prev: RE: Eurotherm2604 modbus support Mark Rivers via Tech-talk
Next: AW: Eurotherm2604 modbus support Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Compiling base on Rocky Linux 9 Wang Xiaoqiang (PSI) via Tech-talk
Next: Re: Compiling base on Rocky Linux 9 Andrew Johnson via Tech-talk
