1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Problems using Universal I/O
To: Timo Korhonen <[email protected]>
Cc: dipirro <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 26 Jan 2023 09:56:23 -0800
This file was developed by me and Javier.
My memory is weak.
I asked Javier or Jerzy to develop these MTCA timing db and substitution based on technical documents, which we got from Jukka.  I didn't develop them, but reviewed and discussed them when we worked together for the MTCA hardware.
Best,
Han
Best,
Han
On Thu, Jan 26, 2023 at 6:22 AM Timo Korhonen via Tech-talk <[email protected]> wrote:
For MTCA specific configuration in mrfioc2, please take a look at the sample configuration here:
https://github.com/epics-modules/mrfioc2/blob/master/evrMrmApp/Db/evr-mtca-300.substitutions
in particular the substitutions for mrmevrout.db (from line 99 onwards). You see lines with FrontUnivOut[0,1], those should do the job for the Universal I/O slots in the front panel.
For the RTM outputs there is no example in the above file but I think you should be able to configure them using definitions like "RearUniv0" etc.
I am a little bit rusty on this so if there is somebody with recent practical experience, I would be happy if you could confirm that this is the case, or give the correct solution.
I hope this helps.
Best regards,
Timo
On 2023-01-26, 08:06, "Tech-talk on behalf of Jukka Pietarinen via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
Hi Giampiero,
From the hardware point of view on the mTCA-EVR-300U the front panel
Universal I/Os are configured/mapped through registers at offset
0x440-0x447 (Front Panel Universal I/O Mapping Registers) and the RTM
Universal I/Os are mapped through registers at offset 0x480-0x493
(Transition Board Output Mapping Registers).
Unfortunately, I cannot help with configuring this through mrfioc2.
Jukka
On 1/25/23 4:53 PM, dipirro via Tech-talk wrote:
> Hi, I have an mrf system set up as follows:
> One mTCA-EVR-300 with 2 Universal I/O LVTTL Output UNIV-TTL and one
> mTCA.4 Rear Transition Module (mTCA-EVRTM-300) with 3 Universal I/O
> LVTTL Output UNIV
> I installed mrfioc2 but I don't know how to configure it to allow the
> use of Universal I/O
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
RE: Problems using Universal I/O GAGET Alexis via Tech-talk
Problems using Universal I/O dipirro via Tech-talk
Re: Problems using Universal I/O Jukka Pietarinen via Tech-talk
Re: Problems using Universal I/O Timo Korhonen via Tech-talk
Re: Problems using Universal I/O Han Lee via Tech-talk
Prev: Re: Problems using Universal I/O Han Lee via Tech-talk
Next: Kernel showing segfaults in motorPoller. Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: RE: Problems using Universal I/O GAGET Alexis via Tech-talk
