1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: linux kernel module for mrfioc2 on MTCA
To: 문건영(선형가속기팀) <[email protected]>
Cc: 박소희 <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 12 Feb 2023 22:03:02 -0800
Great!
Han
On Sun, Feb 12, 2023 at 9:55 PM 문건영(선형가속기팀) <[email protected]> wrote:
Dear Han,
This issue was solved with your help.
You said you only tested the script on Debian. For you information, my OS is buildroot linux, and I didn’t use the sciprt. I changed /usr/share/pci.ids.gz to the pci.ids in your repo.
It works fine.
# lspci -nmn | grep mrf
# lspci -nmn | grep Finland
08:00.0 "Signal processing controller [1180]" "Xilinx Corporation [10ee]" "7-Series FPGA Hard PCIe block (AXI/debug) [7011]" "Micro-Research Finland Oy [1a3e]" "MTCA Event Master 300 [232c]"
0a:00.0 "Signal processing controller [1180]" "Xilinx Corporation [10ee]" "7-Series FPGA Hard PCIe block (AXI/debug) [7011]" "Micro-Research Finland Oy [1a3e]" "MTCA Event Receiver 300 [132c]"
Thank you.
Best regards,
Geonyeong Mun
Sent: Saturday, February 11, 2023 5:43 AM
To:
Cc: [email protected];
Hi GY,
Too late, but I can spend a little time finally.
On Thu, Jan 5, 2023 at 11:15 PM 문건영(선형가속기팀) <[email protected]> wrote:
Dear All,
With the help of Dr. Han, I was able to run mrfioc2.
However, I have one question.
I have one EVG and two EVRs as shown below.
(mTCA-EVM-300, mTCA-EVR-300, mTCA-EVR-300RF)
nat> show_fru
FRU Information:
FRU  Device   State  Name
  0   MCH       M4    NAT-MCH-CM
  3   mcmc1     M4    NAT-MCH-MCMC
  5   AMC1      M4    CCT AM G64/471
  6   AMC2      M4    mTCA-EVM-300
  7   AMC3      M4    mTCA-EVR-300
  8   AMC4      M4    mTCA-EVR-300RF
 40   CU1       M4    Schroff uTCA CU
50   PM1       M4    NAT-PM-AC600D
60   Clock1    M4    MCH-Clock
61   HubMod1   M4    MCH-PCIe
92   AMC3-RTM  M4    mTCA-EVRTM-300
I checked it by referring to lspci of mrfioc2 to distinguish 3 cards.
# dmesg | grep mrf
mrf: loading out-of-tree module taints kernel.
mrf-pci 0000:06:00.0: Attaching MRF device w/o PLX bridge (00007011)
mrf-pci 0000:06:00.0: MRF Setup complete
mrf-pci 0000:09:00.0: Attaching MRF device w/o PLX bridge (00007011)
mrf-pci 0000:09:00.0: MRF Setup complete
mrf-pci 0000:0a:00.0: Attaching MRF device w/o PLX bridge (00007011)
mrf-pci 0000:0a:00.0: MRF Setup complete
# lspci -v -s 6:00.0
06:00.0 Signal processing controller: Xilinx Corporation Device 7011
           Subsystem: Device 1a3e:132c
           Flags: bus master, fast devsel, latency 0, IRQ 16
           Memory at df200000 (32-bit, non-prefetchable) [size=256K]
           Capabilities: [40] Power Management version 3
           Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
           Capabilities: [60] Express Endpoint, MSI 00
           Capabilities: [100] Device Serial Number 00-00-00-00-00-00-00-00
           Kernel driver in use: mrf-pci
           Kernel modules: mrf
# lspci -v -s 9:00.0
09:00.0 Signal processing controller: Xilinx Corporation Device 7011
           Flags: bus master, fast devsel, latency 0, IRQ 18
           Memory at df100000 (32-bit, non-prefetchable) [size=256K]
           Kernel modules: mrf
# lspci -v -s a:00.0
0a:00.0 Signal processing controller: Xilinx Corporation Device 7011
           Subsystem: Device 1a3e:232c
           Memory at df000000 (32-bit, non-prefetchable) [size=512K]
           Kernel modules: mrf
https://github.com/epics-modules/mrfioc2/blob/master/documentation/lspci/mtca-evm-300.txt
In the document above, the device name is specified in the subsystem item as shown below, but I do not.
06:00.0 Signal processing controller: Xilinx Corporation XILINX PCI DEVICE
        Subsystem: Micro-Research Finland Oy MTCA Event Master 300
        Physical Slot: 4
Because that document was generated after manually updating the local pciid file. Please see the repository
After leaving my previous company, I archived it and didn't updated my pciid file from the latest pciid file.
I resume the repo, and merge the latest pciid into the repository. Please check the REAME file. I only test it with Debian11 without any MRF hardware.
After you update your local pciid file with the repository one, you can see the mrf hardware name by executing "lspci."
Note that now 7011 was defined now officially, so I removed my description of that definition.
In addition, my old and stand-alone script https://github.com/icshwi/e3-mrfioc2/blob/master/tools/get_pciaddr.bash may help you get some information also.
I couldn't distinguish between EVG and EVR, so I had to run them one by one.
epics> mrmEvgSetupPCI("EVG","6:00.0")
Notice: devPCIFindSpec() expect B:D.F in hex
PCI Device not found
epics>
epics> mrmEvgSetupPCI("EVG","9:00.0")
epics>
epics>
epics> mrmEvgSetupPCI("EVG","a:00.0")
Device EVG  a:0.0
Using IRQ 16
FPGA version: 280e0207
mTCA-EVM-300 #Inputs FP:3 UV:16 RB:0
EVM automatically creating 'EVG:FCT', 'EVG:EVRD', and 'EVG:EVRU'
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Found SFP EEPROM
Warning: Recommended minimum firmware 2 version is 207.6, found 207.0
Found SFP Strangeness 00000000
Sequencer capability detected
VME 64: Out FP:8 FPUNIV:0 RB:0 IFP:8 GPIO:0
EVR FIFO task start
EVR FIFO task start
PCI interrupt connected!
epics>
epics> mrmEvrSetup'
Unbalanced quote.
epics> mrmEvrSetupPCI("EVR1","slot=4")
PCI Device not found on slot=4
epics> mrmEvrSetupPCI("EVR1","6:00.0")
Device EVR1  6:0.0 slot=(null)
Using IRQ 16
FWVersion 0x18120207
Found version 519
Found SFP EEPROM
mTCA: Out FP:4 FPUNIV:0 RB:16 IFP:2 GPIO:0
EVR FIFO task start
Enabling interrupts
epics> mrmEvrSetupPCI("EVR2","9:00.0")
Device EVR2  9:0.0 slot=(null)
Using IRQ 18
FWVersion 0x18100207
Found version 519
Found SFP EEPROM
EVR FIFO task start
Enabling interrupts
epics>
Is there no problem if I separate it into the above information?
1a3e:232c is mTCA-EVM-300.
1a3e:132c is mTCA-EVR-300RF or mTCA-EVR-300.
I can distinguish the two EVRs after the IOC runs.
Is there any way to know before the IOC is implemented?
Once you plug them into the MTCA chassis, you should know where you plug them in. In addition, you have to configure them seriously within MCH. Sometimes, you have to configure the MTCA backplane settings into MCH. All information must be defined first when configuring your MCH for the clock distribution according to your system configuration. Only the fixed static configuration you have.
So, you'll need to know all static information of your timing hardware before IOC implementation. The one repository and the script I share may help you to define all static information.
HTH,
Han
Best regards,
Geonyeong Mun
_________________________________________
Geonyeong Mun
Staff Engineer, Accelerator Division
Pohang Accelerator Laboratory (PAL)
37673 80 Jigokro-127-beongil, Nam-gu,
Pohang, Gyeongbuk, Korea
phone: +82 10 4164 - 2260
office: +82 54 279 - 1098
email: [email protected]
web: pal.postech.ac.kr
Sent: Thursday, January 5, 2023 3:00 PM
To:
The actual kernel driver is located in
There are several methods you may try, here is also very old repo, but you can find "dkms" information there.
Best,
Han
On Wed, Jan 4, 2023 at 9:57 PM Han Lee <[email protected]> wrote:
Hi Geonyeong,
Please use the kernel driver for mrfiioc2 instead of what you used.
PCIID is not up-to-date, if you want to see through lspci, please check my own archived repo.
HTH,
Han
On Wed, Jan 4, 2023 at 9:41 PM 문건영(선형가속기팀) via Tech-talk <[email protected]> wrote:
Dear All,
I am trying to MTCA-EVG-300 and MTCA-EVR-300U are working on Linux using mrfioc2.
But, the following error is displayed:
epics> mrmEvgSetupPCI("EVG",08,00,0)
Can't open /sys/module/mrf/parameters/interfaceversion in order to read kernel module interface version. Kernel module not loaded or too old.
I used the latest version driver provided by MRF. https://github.com/jpietari/mrf-linux-driver
Do I have to use a driver other than this one?
The mrf directory does not exist In the /sys/module directory.
Instead, pci_mrfevg, pci_mrfevr exists.
# ls /sys/module/pci_mrfev*
/sys/module/pci_mrfevg:
coresize   holders    initstate  refcnt     taint
drivers    initsize   notes      sections   uevent
/sys/module/pci_mrfevr:
# lsmod
Module                  Size  Used by    Tainted: G
pci_mrfevr             57344  0
pci_mrfevg             53248  0
nfsv3                  28672  1
nfs                   135168  2 nfsv3
lockd                  77824  2 nfsv3,nfs
grace                  16384  1 lockd
sunrpc                196608  6 nfsv3,nfs,lockd
x86_pkg_temp_thermal    16384  0
igb                   184320  0
# ls /dev/e*
/dev/ega0  /dev/ega2  /dev/era0  /dev/era2  /dev/erb0  /dev/erb2
/dev/ega1  /dev/ega3  /dev/era1  /dev/era3  /dev/erb1  /dev/erb3
# dmesg | tail
Event Generator PCI/PCIe driver exiting.
Event Receiver PCI/PCIe driver exiting.
Event Generator PCI/PCIe driver init.
mrfevg:BAR0 start df000000 end df07ffff mmaped 41180000
udevd[165]: specified group 'mrf' unknown
Event Receiver PCI/PCIe driver init.
mrfevr:BAR0 start df200000 end df23ffff, mmap 40780000
mrfevr: Device Type: MTCAEVR300
mrfevr:BAR0 start df100000 end df13ffff, mmap 41040000
Best regards,
Geonyeong Mun
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
linux kernel module for mrfioc2 on MTCA 문건영(선형가속기팀) via Tech-talk
Re: linux kernel module for mrfioc2 on MTCA Han Lee via Tech-talk
RE: linux kernel module for mrfioc2 on MTCA 문건영(선형가속기팀) via Tech-talk
Prev: RE: linux kernel module for mrfioc2 on MTCA 문건영(선형가속기팀) via Tech-talk
Next: PilatusDetector-Requested threshold (0.00 eV) is out of range 鲍康文 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Scan rate '.01 second' not achievable Barrett (US), Patrick E via Tech-talk
