1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Multiple sequencer instances undesirably sharing information
From: Jure Varlec via Tech-talk <[email protected]>
To: Talk EPICS Tech <[email protected]>
Date: Tue, 14 Feb 2023 13:30:59 +0000
I'd like to add a couple of points here. First, while the sequencer program options can be specified in the Makefile, they change the semantics of the program so much that it is better to declare them in the program itself; they are effectively part of it. Changing them may require a redesign of the program.
Second, and more importantly, I suggest you always specify the +s option, which enables safe mode [1]. Apart from enabling cool stuff like anonymous channels (which are much easier to use than synchronizing with event flags), it ensures your variables are only updated at well-defined times. And that's critically important! Without the +s flag, it's possible for a monitored variable to change its value at any time. You can't reason about your program logic in such a situation.
Just a couple of cents from someone who observed variables change values in the middle of an action block and couldn't believe that +s was only introduced in version 2.1.
Best,
Jure
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Wednesday, February 8, 2023 23:18
To: Pete Jemian <[email protected]>; Mark Rivers <[email protected]>
Cc: SWC <[email protected]>; Talk EPICS Tech <[email protected]>
Caution: This email originated from outside of Cosylab.
Thanks, i was looking at this: https://www-csr.bessy.de/control/SoftDist/sequencer/Reference.html?highlight=option#option
but its also in there, so anyway there is that.
Best regards,
Marco
Sent: 08 February 2023 19:16
To: Marco A. Barra Montevechi Filho <[email protected]>; Mark Rivers <[email protected]>
+r is in this documentation:
https://epics.anl.gov/EpicsDocumentation/AppDevManuals/Sequencer/snl_1.9_man.html
On 2/8/2023 4:15 PM, Marco A. Barra Montevechi Filho wrote:
> https://epics.anl.gov/EpicsDocumentation/AppDevManuals/Sequencer/snl_1.9_man.html <https://epics.anl.gov/EpicsDocumentation/AppDevManuals/Sequencer/snl_1.9_man.html>
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
       Education is the one thing for which people
          are willing to pay yet not receive.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Multiple sequencer instances undesirably sharing information Marco A. Barra Montevechi Filho via Tech-talk
Re: Multiple sequencer instances undesirably sharing information Jemian, Pete R. via Tech-talk
Re: Multiple sequencer instances undesirably sharing information Marco A. Barra Montevechi Filho via Tech-talk
RE: Multiple sequencer instances undesirably sharing information Mark Rivers via Tech-talk
Re: Multiple sequencer instances undesirably sharing information Pete Jemian via Tech-talk
Prev: RE: Archiver appliance sampling buffer overflows after migration from Version 2018 to Version 1.1.0 Wang, Lin via Tech-talk
Next: Help getting modbus module started Christian Pauly via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Multiple sequencer instances undesirably sharing information Marco A. Barra Montevechi Filho via Tech-talk
Next: Open Position at PSI/SLS 2.0 Project Yao Xingxing via Tech-talk
