1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re:Re: Segmentation fault (core dumped) using SimDetector ioc
To: "Mark Rivers" <[email protected]>
Date: Tue, 7 Mar 2023 13:01:26 +0800 (CST)
Hi Mark,
        It was ok, after I downloaded and rebuild the ADSimulator module.
        But I got another error when make support:
make[5]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/configure'
make -C ./iocEiger1 clean
make -C ./iocEiger2 clean
make[6]: Entering directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/iocBoot/iocEiger1'
make[6]: Entering directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/iocBoot/iocEiger2'
make -C ./src clean
make[6]: Entering directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/eigerApp/src'
rm -f cdCommands envPaths dllPath.bat relPaths.sh
make[6]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/iocBoot/iocEiger2'
make[6]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/iocBoot/iocEiger1'
make[5]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/iocBoot'
rm -rf O.linux-x86_64 O.Common
make[6]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/eigerApp/src'
make[5]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC/eigerApp'
make[4]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs/eigerIOC'
make[3]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger/iocs'
make[2]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master/ADEiger'
make[1]: Leaving directory '/opt/EPICS/synApps_6_1/support/areaDetector-master'
make: *** [/opt/EPICS/base/configure/RULES_DIRS:84: /opt/EPICS/synApps_6_1/support/areaDetector-master.clean] Error 2
     Rebuild asyn, areaDetector and ADEiger module did not help the error.
     Until now ioc worked well even the error, or I have not found it.
     I think it is better to eliminate the error.
     Could some give me some instruction.
    Rocky 9(64),base 7  synapps 6_1, asyn and Detector module from github the last two weeks.
Lynn
在 2023-03-03 21:45:17,"Mark Rivers" <[email protected]> 写道:
Hi Lynn
That is an unusual place to see a seg fault.  I suspect it was not built correctly, so you are mixing code from two versions of some module.  I suggest rebuilding EPICS base and all of the synApps modules that ADSimdetector uses, so you are sure everything built with the same versions.  For base and each module type the following at the top-level
make clean uninstall
make -sj
If you still have the problem then run the ADSimDetector under gdb like this.
linux> gdb ../../bin/linxux-86_64/simDetectorApp
gdb> run st.cmd
When it crashes type this gdb command
gdb> backtrace
Send the output.
Sent: Friday, March 3, 2023 3:50 AM
Subject: Segmentation fault (core dumped) using SimDetector ioc
Hi Mark and all,
     I met "Segmentation fault" error when using SimDetector.
     I use rocky9(64) , asyn and areaDetector from git.
     When I executed st.cmd.linux. I got these as below:
lynn
Shell output:
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", "10000000")
# Create a simDetector driver
#simDetectorConfig(const char *portName, int maxSizeX, int maxSizeY, int dataType, int maxBuffers, int maxMemory, int priority, int stackSize)
simDetectorConfig("SIM1", 1024, 1024, 1, 0, 0)
Hereis st.cmd file:
epicsEnvSet("IOC","iocSimDetector")
epicsEnvSet("TOP","/opt/EPICS/synApps_6_1/support/areaDetector-master/ADSimDetector/iocs/simDetectorIOC")
epicsEnvSet("ADSIMDETECTOR","/opt/EPICS/synApps_6_1/support/areaDetector-master/ADSimDetector/iocs/simDetectorIOC/../..")
epicsEnvSet("SUPPORT","/opt/EPICS/synApps_6_1/support")
epicsEnvSet("ASYN","/opt/EPICS/synApps_6_1/support/asyn-R4-37")
epicsEnvSet("AREA_DETECTOR","/opt/EPICS/synApps_6_1/support/areaDetector-master")
epicsEnvSet("ADSUPPORT","/opt/EPICS/synApps_6_1/support/areaDetector-master/ADSupport")
epicsEnvSet("ADCORE","/opt/EPICS/synApps_6_1/support/areaDetector-master/ADCore")
epicsEnvSet("AUTOSAVE","/opt/EPICS/synApps_6_1/support/autosave-R5-10")
epicsEnvSet("BUSY","/opt/EPICS/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("CALC","/opt/EPICS/synApps_6_1/support/calc-R3-7-3")
epicsEnvSet("SNCSEQ","/opt/EPICS/synApps_6_1/support/seq-2-2-6")
epicsEnvSet("SSCAN","/opt/EPICS/synApps_6_1/support/sscan-R2-11-3")
epicsEnvSet("DEVIOCSTATS","/opt/EPICS/synApps_6_1/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/opt/EPICS/base")
errlogInit(20000)
dbLoadDatabase("$(TOP)/dbd/simDetectorApp.dbd")
simDetectorApp_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("PREFIX", "13SIM1:")
epicsEnvSet("PORT",   "SIM1")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "1024")
epicsEnvSet("YSIZE",  "1024")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CBUFFS", "500")
epicsEnvSet("MAX_THREADS", "8")
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db")
#asynSetMinTimerPeriod(0.001)
simDetectorConfig("$(PORT)", $(XSIZE), $(YSIZE), 1, 0, 0)
# To have the rate calculation use a non-zero smoothing factor use the following line
#dbLoadRecords("simDetector.template",     "P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1,RATE_SMOOTH=0.2")
dbLoadRecords("$(ADSIMDETECTOR)/db/simDetector.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
# Create a second simDetector driver
##simDetectorConfig("SIM2", 300, 200, 1, 50, 50000000)
##dbLoadRecords("$(ADSIMDETECTOR)/db/simDetector.template","P=$(PREFIX),R=cam2:,PORT=SIM2,ADDR=0,TIMEOUT=1")
# Load an NDFile database.  This is not supported for the simDetector which does not write files.
#dbLoadRecords("NDFile.template","P=$(PREFIX),R=cam1:,PORT=SIM1,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin, set it to get data from first simDetector driver.
NDStdArraysConfigure("Image1", 20, 0, "$(PORT)", 0, 0, 0, 0, 0, 5)
# This creates a waveform large enough for 2000x2000x3 (e.g. RGB color) arrays.
# This waveform only allows transporting 8-bit images
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=UCHAR,NELEMENTS=12000000")
# This waveform only allows transporting 16-bit images
#dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int16,FTVL=SHORT,NELEMENTS=12000000")
# This waveform allows transporting 32-bit images
#dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int32,FTVL=LONG,NELEMENTS=12000000")
# This waveform allows transporting 64-bit float images
#dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Float64,FTVL=DOUBLE,NELEMENTS=12000000")
# Load all other plugins using commonPlugins.cmd
< $(ADCORE)/iocBoot/commonPlugins.cmd# Create a standard arrays plugin, set it to get data from FFT plugin.
NDStdArraysConfigure("Image2", 3, 0, "FFT1", 0)
# This waveform allows transporting 64-bit images, so it can handle any detector data type at the expense of more memory and bandwidth
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image2:,PORT=Image2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FFT1,TYPE=Float64,FTVL=DOUBLE,NELEMENTS=12000000")
set_requestfile_path("$(ADSIMDETECTOR)/simDetectorApp/Db")
asynSetTraceIOMask("$(PORT)",0,2)
iocInit()
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P=$(PREFIX)")
Re: Re:Re: Segmentation fault (core dumped) using SimDetector ioc Mark Rivers via Tech-talk
Segmentation fault (core dumped) using SimDetector ioc lynn via Tech-talk
Prev: RE: Ways to know if instrument connected via TCP/IP through StreamDevice has lost connection Wang, Andrew via Tech-talk
Next: areadetector on windows, xml2 William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Segmentation fault (core dumped) using SimDetector ioc Mark Rivers via Tech-talk
Next: Re: Re:Re: Segmentation fault (core dumped) using SimDetector ioc Mark Rivers via Tech-talk
