1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: DeferredMoves without setting moving flag
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Laurenz Rettig <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 10 Mar 2023 17:00:55 +0000
Hej Lorenz,
>I've been working on an asyn motor controller with DeferredMoves.
good to hear.
>This in principle works, however I noticed that when DeferedMoves is enabled,
>and I change the setpoint of an axis, the moving flag is raised for a short time (i.e. DMOV=0),
>even though the axis is not moving yet.
Hm. There are 2 different instances involved here:
the motorRecord (as a record, doing its statemachine business)
and the (model 3) driver handling defered moves.
The record is educated to aloways have a DMOV == false -> DMOV == true -> DMOV transition,
when you write to the .VAL field of the record.
This is to help scripts relying on a callback.
If an automated script generates a new setpoint, and the setpoint is the same as the old one,
or very close to the old one, the motor will not (need to) move.
however, the script gets a callback, as expected.
The deferred moves are generated in the driver, and you talk to another record, right ?
So that the motorRecord has no idea about the deferred status.
>I would like to get rid of this behavior.
That is understandable.
The only solution I can think of spontaneously would be to move the "deferred feature" into the
motorRecord itself.
Not impossible, but needs some/much thinking and testing.
how big is the pain-level at your side?
Greetings to Berlin
/Torsten
From: Tech-talk <[email protected]> on behalf of Laurenz Rettig via Tech-talk <[email protected]>
Reply-To: Laurenz Rettig <[email protected]>
Date: Friday, 10 March 2023 at 17:17
Subject: DeferredMoves without setting moving flag
I've been working on an asyn motor controller with DeferredMoves. This in principle works, however I noticed that when DeferedMoves is enabled, and I change the setpoint of an axis, the moving flag is raised for a short time (i.e. DMOV=0), even though the axis is not moving yet. I would like to get rid of this behavior.
As far as I understand it, this is probably induced by the calls to "pAxis->setIntegerParam(motorStatusDone_, 0);" here:
https://github.com/epics-modules/motor/blob/34474ed958838ea5083f598fa4bd9f1ca7e1821c/motorApp/MotorSrc/asynMotorController.cpp#L317
and the flag is reset by the next call of the axis poll() function.
Is there a simple way to avoid this, or do I have to rewrite the whole writeFloat64 function in my controller driver, and remove these lines?
Laurenz
Dr. Laurenz Rettig                  [email protected]
Emmy Noether Research Group Dynamics of Correlated Materials
Fritz Haber Institute of the Max Planck Society
Department of Physical Chemistry
Faradayweg 4-6                         Tel: +49 30 8413 5225
14195 Berlin, Germany                  Fax: +49 30 8413-5387
DeferredMoves without setting moving flag Laurenz Rettig via Tech-talk
Prev: RE: [EXTERNAL] DeferredMoves without setting moving flag Pearson, Matthew via Tech-talk
Next: Re: [EXTERNAL] DeferredMoves without setting moving flag Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: asyn R4-44 available Mark Rivers via Tech-talk
