1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: asyn R4-44 available
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 13 Mar 2023 21:13:10 +0000
Folks,
asyn R4-44 is now available. This is from the release notes:
- devEpics
  - Rewrite the device support for arrays.
    Previously it used a large C macro to be able to support int8, int16, int32, float32, and float64
    data types without a lot of repetitive code.  This was changed to use a C++ template file.
  - Previously only the waveform record was supported for arrays.  Added support for aai and aoo records.
  - Add new devEpicsPvt functions (from Michael Davidsaver):
    - Avoids leaking DBENTRY during initialization.
    - Use dbInitEntry() from record rather than dbFindRecord() when available.
    - Reduces duplicate code.
- Documentation:
  - Converted all HTML files in documentation/ to Sphinx RST files in docs/source.
  - It uses the Read The Docs theme (sphinx-rtd-theme) which provides a panel
    on the left side of the screen for easy navigation.
  - Added Github actions to publish the Sphinx generated documentation to Github Pages.
  - The new home page for the asyn documentation is https://epics-modules.github.io/asyn.
  - Converted documentation/RELEASE_NOTES.html to RELEASE.md.
- testErrorsApp
  - Add aai and aao records to databases in order to test new device support for these.
- Fix testing on Github Actions by forcing TIRPC=YES, required for modern Linux releases.
Home: https://github.com/epics-modules/asyn
Documentation: https://epics-modules.github.io/asyn
Release notes: : https://github.com/epics-modules/asyn/blob/master/RELEASE.md
asyn R4-44-1 available Mark Rivers via Tech-talk
Prev: RE: [EXTERNAL] DeferredMoves without setting moving flag Pearson, Matthew via Tech-talk
Next: pv/ntndarray.h not found in areaDetector compilation Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: DeferredMoves without setting moving flag Torsten Bögershausen via Tech-talk
Next: asyn R4-44-1 available Mark Rivers via Tech-talk
ANJ, 15 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
