Hello Tong, You are correct and Kay also indicated this was fixed February 2, 2023. I was using an old tagged version 4.6.6. The current master works as-expected!
Thanks, all. -ps
I also came across the similar issue but I was trying to access the widget property, e.g. $(name) through an argument of a command. And I believe this PR resolved it
https://github.com/ControlSystemStudio/phoebus/pull/2532
If it does not support env, either report a new issue, or try to use a dummy property of a widget to host the env, and use it in a command, for multiple envs, you can also parse the string in your command into multiple variables.
Tong
Paul Sichta via Tech-talk
Sent: Friday, March 17, 2023 17:19
To: [email protected]
Subject: using macros in Action, Execute Command
[EXTERNAL] This email originated from outside of FRIB
Using phoebus, I used an action button and added an Execute Command. My macro will not work when used in the Command line. The macro will work in action type WritePV, or as a PVname for an object on the display.
Example: I add to my environment before starting phoebus, export myLS=ls
In the action command line I use $(myLS)
When I run the action I get an error
Cannot run program "$myLS" (in directory blah...); error=2, No such file or directory
If I simply use ls in the command it works fine.
The help, about, inspect environmental variables it shows: myLS = ls
Is there a way to use macros from the user's environment on these Execute Commands?
In particular, I want to use a macro to be a directory path on my system
- using macros in Action, Execute Command Paul Sichta via Tech-talk
- RE: using macros in Action, Execute Command Zhang, Tong via Tech-talk
Re: Output records in StreamDevice Zimoch Dirk via Tech-talk
RE: [External] Re: Output records in StreamDevice Leblanc, Gregory via Tech-talk
<2023>
2025
2026
Phoebus: using macros in Action, Execute Command Paul Sichta via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
