1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Phoebus Alarm Log Can't Display History
From: Han Gao - Lotus via Tech-talk <[email protected]>
Date: Thu, 23 Mar 2023 01:33:59 +0000
Hi All,
I’m trying to display Phoebus alarm history from elastic search using the “Alarm Log Table”. But there is an error:
[org.phoebus.framework.jobs] Job 'searching alarm log messages for : *' failed
com.sun.jersey.api.client.UniformInterfaceException: GET http://localhost:9200/search/alarm?current_message=*&severity=*&current_severity=*&size=10000&pv=*&root=*&start=7+days&host=*&end=now&message=*&user=*&command=* returned a response status of 405 Method Not Allowed
I use Phoebus 4.6, elastic search 8.6. Kibana. Phoebus alarm table can display the active alarms.
Looking at the elastic-search with Kibana and curl, the data there look perfectly fine.
For Phoebus, I added following settings according to the template (settings_template.ini) :
# Package org.phoebus.applications.alarm.logging.ui
org.phoebus.applications.alarm.logging.ui/service_uri = http://localhost:9200
org.phoebus.applications.alarm.logging.ui/results_max_size = 10000
Is there anything wrong? How do I fix this error? Any reply is appreciated.
Best regards,
Lotus Gao
Re: Phoebus Alarm Log Can't Display History Giovanni Savarese LNL via Tech-talk
Prev: Doubts about libpcre in compilation Marco A. Barra Montevechi Filho via Tech-talk
Next: Differences between using disconnectOnReadTime in asynSetOption and asyn record Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Doubts about libpcre in compilation NICOLE Remi via Tech-talk
Next: Re: Phoebus Alarm Log Can't Display History Giovanni Savarese LNL via Tech-talk
