1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Differences between using disconnectOnReadTime in asynSetOption and asyn record
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Thu, 23 Mar 2023 12:47:11 +0000
Hi all,
I have a clarification question regarding setting a port to disconnect upon a read timeout. In the asynRecord documentation, there is a DRTO field in the IP Control Fields section (https://epics-modules.github.io/asyn/asynRecord.html#ip-control-fields) for that. Meanwhile, in the asynDriver documentation (https://epics.anl.gov/modules/soft/asyn/R4-29/asynDriver.html), the disconnectOnReadTimeout key can be used for asynSetOption. Is there a difference between the two approaches for disconnecting a port upon a read timeout?
Andy
Purple ribbon awareness
Re: Differences between using disconnectOnReadTime in asynSetOption and asyn record Mark Rivers via Tech-talk
Prev: Phoebus Alarm Log Can't Display History Han Gao - Lotus via Tech-talk
Next: Other approaches to disabling a record from processing if there is no connection? Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: RE: Phoebus Alarm Log Can't Display History CAOUEN Loic via Tech-talk
Next: Re: Differences between using disconnectOnReadTime in asynSetOption and asyn record Mark Rivers via Tech-talk
