1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: RE: Phoebus Alarm Log Can't Display History
From: CAOUEN Loic via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 3 Apr 2023 14:36:53 +0000
Hello,
As Giovanni said, you must configure the alarm_logger ip and port in phoebus settings, not the elasticsearch ip and port.
If you haven’t changed the default port of you alarm_logger, you must add these settings :
org.phoebus.applications.alarm.logging.ui/service_uri = http://localhost:8080
org.phoebus.applications.alarm.logging.ui/results_max_size = 10000
Replace localhost by the external ip if it’s on another server.
Loïc
De : Tech-talk <tech-talk-bounces at aps.anl.gov> De la part de Giovanni Savarese LNL via Tech-talk
Envoyé : vendredi 31 mars 2023 14:40
À : tech-talk at aps.anl.gov
Objet : Re: Phoebus Alarm Log Can't Display History
I also tried to use the phoebus alarm server and alarm logger and just recently I reached a working condition.
From your message I think the problem is the port you are pointing to which should be 9000 or 8080 based on the alarm-logger version. In fact the alarm-logger service communicate with the elasticsearch server using port 9200 whereas the phoebus client execute the GET request pointing to the alarm-logger service which expose port 900 or 8080 based on the version you used. For me the main problem was find the correct version of the services and the client to work together and consequently set org.phoebus.applications.alarm.logging.ui/service_uri to the correct port and endpoint.
In my case I mainly use docker contaneirs; so, if you want, at this repository https://github.com/giosava94/docker-phoebus-alarm I created a docker image, based on the v4.7.1 tag of phoebus, for the alarm server and the alarm logger. Moreover I prepared a docker-compose.yml file with the complete system configuration: zookeper, kafka, alarm-server, elasticsearch and alarm-logger (optional kibana).
Let me know if you or anyone else find it useful or if there are problems (in that case I'm not an expert about these systems so I don't garantee an immediate or clear answer).
Regards
Giovanni S
On 23/03/23 02:33, Han Gao - Lotus via Tech-talk wrote:
Hi All,
I’m trying to display Phoebus alarm history from elastic search using the “Alarm Log Table”. But there is an error:
[org.phoebus.framework.jobs] Job 'searching alarm log messages for : *' failed
com.sun.jersey.api.client.UniformInterfaceException: GET http://localhost:9200/search/alarm?current_message=*&severity=*&current_severity=*&size=10000&pv=*&root=*&start=7+days&host=*&end=now&message=*&user=*&command=* returned a response status of 405 Method Not Allowed
I use Phoebus 4.6, elastic search 8.6. Kibana. Phoebus alarm table can display the active alarms.
Looking at the elastic-search with Kibana and curl, the data there look perfectly fine.
For Phoebus, I added following settings according to the template (settings_template.ini) :
# Package org.phoebus.applications.alarm.logging.ui
org.phoebus.applications.alarm.logging.ui/service_uri = http://localhost:9200
Is there anything wrong? How do I fix this error? Any reply is appreciated.
Best regards,
Lotus Gao
Phoebus Alarm Log Can't Display History Han Gao - Lotus via Tech-talk
Re: Phoebus Alarm Log Can't Display History Giovanni Savarese LNL via Tech-talk
Prev: Sending messages to Phoebus via Protobuf Mihnea Romanovschi - STFC UKRI via Tech-talk
Next: Digital status mask? William F Badgett Jr via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Phoebus Alarm Log Can't Display History Giovanni Savarese LNL via Tech-talk
Next: Differences between using disconnectOnReadTime in asynSetOption and asyn record Wang, Andrew via Tech-talk
ANJ, 03 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
