1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer.
From: Florian Feldbauer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 15 May 2023 09:49:58 +0200
Hey all,
we are also working with IOCs running inside Docker Containers, using Modbus, StreamDevice (via serial and TCP ports), and a lot more. We have not seen any issues so far. All our IOCs are running stable.
Regarding our experience with network: If not using `net = host` for the container, the UDP broadcast does not seem to be forwarded, and thus IOCs on different Hosts (or in separated Docker networks) are not seen by CA/PVacces.
But usually we only have a single IOC per host, so we simply use `net = host` for our containers.
Another possibility we tested is to have multiple IOC in individual containers using a dedicated docker network and run a Gateway + reverse gateway (either directly on the host or inside a container with `net = host`) to establish CA communication of our IOCs on one host to other hosts.
Cheers,
Florian
On 5/15/23 09:38, Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk wrote:
I'd just like to add that we have several IOCs running in containers including AreaDetector (Aravis) and motion controllers (turbo pmac) and have not seen any issue like this.
However, I have yet to try a Stream Device, so I'm interested to see your results, Andrew.
There, challenges with CA discovery and container networking. Our solution is to use the host network in our IOC containers. How have you solved this and are you able to verify that network routing to/between containers is working?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Wang, Andrew via Tech-talk <tech-talk at aps.anl.gov>
Sent: 13 May 2023 00:27
To: Mark Rivers <rivers at cars.uchicago.edu>; Zimoch Dirk <dirk.zimoch at psi.ch>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Subject: RE: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer.
Hi Mark and Dirk,
Thank you for your responses. I will do my best to identify if it is a container or EPICS issue by separating out the IOC from the container as soon as possible. It won’t be until later next week unfortunately.
Sent: Friday, May 12, 2023 3:29 PM
To: Zimoch Dirk <dirk.zimoch at psi.ch>; Wang, Andrew <wang126 at llnl.gov>
Timeouts in the protocol should be recoverable.  From what I understand once this happens all CA access to the IOC is lost.  If so, this is a more serious issue.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Zimoch Dirk via Tech-talk
Sent: Friday, May 12, 2023 2:16 PM
To: Wang, Andrew <wang126 at llnl.gov>
Hi Andy,
I suspect your container stalls from time to time, causing timeouts in the protocol.
I do not think that containers have been designed with real-time performance in mind. Thus I am not really surprised that it does not behave like a pure host. Maybe you can tune how the host schedules the containers? Or reduce the number of containers per host? It may simply be overburdened. Do you have any figures on the system load?
Dirk
Am 12.05.2023 um 20:06 schrieb Wang, Andrew via Tech-talk <tech-talk at aps.anl.gov>:
Hi all,
I have created multiple IOCs for the project in which I am involved. They are all running in their own Docker container in a host computer running Ubuntu 20.04. In each Docker container, the following EPICs and support module versions are used.
  1. EPICS: 7.0.4
  2. StreamDevice: 2.8.15
  3. Asyn: 4.41
In one of the IOCs, I have a SSEQ record that is used to push a scalar value to multiple records that set four parameters for the target instrument. There is an instance where streamDevice is unable to push the value to the second parameter, causing the protocol to abort. Then, a few minutes later, my colleagues and I have observed that no records from the IOC in question can be accessed through Channel Access. This is the error message that we receive.
Read operation timed out: some PV data was not read.
<RECORD_NAME> 0
CA.Client.Exception……………………………………………………..
Warning: “Virtual circuit disconnect”
Context: “op=0, channel=<RECORD_NAME>, type=DBR_TIME_DOUBLE, count=1, ctx=”<IP ADDRESS:PORT>”
Source File: ../getCopy.cpp line 91
Current Time: <TIME>
This also meant that I was unable to check the STAT field to see what the cause of the abortion was.
Thank you and I look forward to hearing back from everyone.
Andy
Purple ribbon awareness
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Wang, Andrew via Tech-talk
Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Zimoch Dirk via Tech-talk
RE: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Mark Rivers via Tech-talk
RE: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Wang, Andrew via Tech-talk
Prev: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Next: _registerRecordDeviceDriver warning David A. Slimmer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
ANJ, 18 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
