1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: warning: multiple interrupt callbacks between processing when running testAsynPortDriverApp
From: "Wang, Lin via Tech-talk" <[email protected]>
To: [email protected]
Date: Mon, 22 May 2023 16:49:12 +0800 (GMT+08:00)
Dear all,
testAsynPortDriver is a pretty good example for learning basic usage of asynPortDriver, however I encountered a warning message that I do not understand when made some modifications and ran it.
The initial status of the digital scope simulator is "Stop", if I try to set the initial status to "Run" by changing Line 102 of https://github.com/epics-modules/asyn/blob/master/testAsynPortDriverApp/src/testAsynPortDriver.cpp
from
setIntegerParam(P_Run,               0);
to
setIntegerParam(P_Run,               1);
then make and add "asynSetTraceMask("testAPD", 0, 0x20)" to the end of st.cmd, the following warning will display continuously,
epics>
epics>
epics> 2023/05/22 01:05:14.319 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:14.819 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:15.320 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:15.820 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:16.320 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:16.820 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:17.321 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:17.821 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:18.322 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
2023/05/22 01:05:18.822 testAPD:scope1:Waveform_RBV devAsynXXXArray::process, warning: multiple interrupt callbacks between processing
In order to install the old MEDM, the test environment is old as follows,
Debian 7 wheezy
base-3.14.12.5
asyn-R4-44-2
Any hint or suggestion is appreciated.
Lin
Re: warning: multiple interrupt callbacks between processing when running testAsynPortDriverApp Maren Purves via Tech-talk
RE: warning: multiple interrupt callbacks between processing when running testAsynPortDriverApp Mark Rivers via Tech-talk
Prev: RE: Looking for a Water (LCW) Leak Sensor for machine interlock Guerrero, Christopher via Tech-talk
Next: Re: warning: multiple interrupt callbacks between processing when running testAsynPortDriverApp Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: RE: Optimal way to offer readback of PV from one IOC as a PV within another IOC Pearson, Matthew via Tech-talk
