1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: no bin file
To: lynn <[email protected]>, tech-talk <[email protected]>
Date: Mon, 22 May 2023 18:35:04 +0000
  •   Then i modified the motorAcs file as i need.
  •   Now, there is not bin file after i make it.
The bin file is created in the motorAcs/iocs/acsIOC/acsApp/src directory.  The iocs/ directory does not get built by default.  You can cd to the iocs/ directory and run “make” and it will be built.
From: Tech-talk <[email protected]> On Behalf Of lynn via Tech-talk
Sent: Monday, May 22, 2023 10:14 AM
To: tech-talk <[email protected]>
Subject: no bin file
Hi all,
    Recently, i try to modify the dirver of motorAcs.
    All environment about epics,motor,asyn was good and run well.
    I downloaded motorAcs file from https://github.com/epics-motor/motorAcs.
    Could someone tell me how to make the bin file came out? Because i just know type: ../../bin/ st.cmd to start it.
Lynn
Image removed by sender.
lynn
Re:RE: no bin file lynn via Tech-talk
Prev: PVA Gateway Logging Problem Murray, Doug via Tech-talk
Next: RE: warning: multiple interrupt callbacks between processing when running testAsynPortDriverApp Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: no bin file lynn via Tech-talk
Next: Re:RE: no bin file lynn via Tech-talk
