Hi all, Nowadayas i was writing elmo motor driver. i modified from MCB4BDriver.cpp (model 3 example). I found it was in a loop from AsynTrace message, after starting st.cmd. ********************* AsynTrace out, Begin************************* 2023/05/24 18:30:14.347 wrote 3 to 192.168.1.5:5001 udp, return asynSuccess. 2023/05/24 18:30:14.347 asynOctetSyncIO wrote: PX; 2023/05/24 18:30:14.347 192.168.1.5:5001 udp read. 2023/05/24 18:30:14.350 192.168.1.5:5001 udp (from 192.168.1.5:5001) read 11 PX;-106202; 2023/05/24 18:30:14.350 serial1 read 11 bytes eom=0 PX;-106202; 2023/05/24 18:30:14.350 192.168.1.5:5001 udp read. 2023/05/24 18:30:16.352 serial1 read from low-level driver returned 1 2023/05/24 18:30:16.352 serial1 queueUnlockPort 2023/05/24 18:30:16.352 serial1 asynManager::queueUnlockPort waiting for event 2023/05/24 18:30:16.352 serial1 queueUnlockPort unlock mutex 0x7f605c000e90 complete. 2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort locking port 2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort taking mutex 0x7f605c000e90 2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort queueing request 2023/05/24 18:30:16.452 serial1 addr -1 queueRequest priority 0 not lockHolder 2023/05/24 18:30:16.452 serial1 schedule queueRequest timeout in 2.000000 seconds 2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort waiting for event 2023/05/24 18:30:16.452 asynManager::portThread port=serial1 callback 2023/05/24 18:30:16.452 serial1 asynManager::queueLockPortCallback signaling begin event 2023/05/24 18:30:16.452 serial1 asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort 2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort got event from callback 2023/05/24 18:30:16.452 serial1 flush 2023/05/24 18:30:16.452 192.168.1.5:5001 udp flush 2023/05/24 18:30:16.452 192.168.1.5:5001 udp write. 2023/05/24 18:30:16.452 192.168.1.5:5001 udp write 3 PX; 2023/05/24 18:30:16.452 wrote 3 to 192.168.1.5:5001 udp, return asynSuccess. Another loop begin. ************* AsynTrace out, End ****************** Since loop was about "px;", I checked driver.cpp, found that "PX" only came out in MCB4BAxis::poll function. Here is the code of MCB4BAxis::Poll. ********************* MCB4BAxis::poll Begin ************************* asynStatus MCB4BAxis::poll(bool *moving) { int done; int driveOn; int limit; double position; asynStatus comStatus; sprintf(pC_->outString_, "PX;"); comStatus = pC_->writeReadController(); if (comStatus) goto skip; position = atof(&pC_->inString_[3]); setDoubleParam(pC_->motorPosition_, position); // Read the moving status of this motor sprintf(pC_->outString_, "ID;"); comStatus = pC_->writeReadController(); if (comStatus) goto skip; done = (float(pC_->inString_[3]) > 0.009) ? 1:0; setIntegerParam(pC_->motorStatusDone_, done); *moving = done ? false:true; ********************* MCB4BAxis::poll End ************************* Could someone help me with these questions: 1) why command "ID;" did not work? Both "PX;" and "ID;" were in MCB4BAxis::poll function. Obviously, "PX;" was send ,"ID;" didn't. 2) how to achieve it, if I want to send some initialization command ? 3) When I send "px;". Device would not send "PX=15926;" back. It would send "px;" first,then "15268;". I means, they are not send together. Does I need to change some in my code? 4) Device required command "PR=1000;", then send "BG;". it would not work if send together. How to write these code ? if (relative) { sprintf(pC_->outString_, "PR=%d;", NINT(position)); sprintf(pC_->outString_, "BG;"); // I added a line here. Does it ok? } else { sprintf(pC_->outString_, "PA=%d;", NINT(position)); sprintf(pC_->outString_, "BG;"); Any suggestion was appreciate. Thanks. Regards, Lynn
ANJ, 26 May 2023 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
