1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: some motor driver 3 questions
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>, lynn <lynn0703 at yeah.net>
Date: Fri, 26 May 2023 13:27:03 +0000
1) why command "ID;" did not work? Both "PX;" and "ID;" were in MCB4BAxis::poll function. Obviously, "PX;" was send ,"ID;" didn't.
You see this in the output:
2023/05/24 18:30:14.350 serial1 read 11 bytes eom=0
PX;-106202;
2023/05/24 18:30:14.350 192.168.1.5:5001 udp read.
2023/05/24 18:30:16.352 serial1 read from low-level driver returned 1
So the low-level read returned 1, which is asynTimeout.  This is interpreted as an error condition.  It expects 0, asynSuccess.
The code is here:
 sprintf(pC_->outString_, "PX;");
  comStatus = pC_->writeReadController();
  if (comStatus) goto skip;
So if comStatus is not 0 it jumps to "skip" and does not send the ID command.
I don't see any \r or \n in the response from the device.  Does it use a semicolon (';') as the terminator?  If so you need to set that with asynOctetSetInputEos in your startup script.
    2) how to achieve it, if I want to send some initialization command ?
You can send an initialization command in the axis or controller constructor code.
   3)
    When I send "px;". Device would not send "PX=15926;" back.
    It would send "px;" first,then "15268;". I means, they are not send together.
    Does I need to change some in my code?
I think you need to set the terminator to ;.  Then you need to do 2 reads to read the response.  The first will read px, the second will read the value.
    4)
    Device required command "PR=1000;", then  send "BG;". it would not work if send together.
    How to write these code ?
    if (relative) {    sprintf(pC_->outString_, "PR=%d;", NINT(position));
    sprintf(pC_->outString_, "BG;");                                   // I added a line here. Does it ok?
  } else {
    sprintf(pC_->outString_, "PA=%d;", NINT(position));
That code is not correct.  You need to change it to this:
  } else {
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of lynn via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, May 24, 2023 7:11 AM
Subject: some motor driver 3 questions
 Hi all,
    Nowadayas i was writing elmo motor driver.
    i modified from MCB4BDriver.cpp (model 3 example).
    I found it was in a loop from AsynTrace message, after starting st.cmd.
********************* AsynTrace out, Begin*************************
2023/05/24 18:30:14.347 wrote 3 to 192.168.1.5:5001 udp, return asynSuccess.
2023/05/24 18:30:14.347 asynOctetSyncIO wrote:
PX;
2023/05/24 18:30:14.347 192.168.1.5:5001 udp read.
2023/05/24 18:30:14.350 192.168.1.5:5001 udp (from 192.
168.1.5:5001) read 11
PX;-106202;
PX;-106202;
2023/05/24 18:30:16.352 serial1 queueUnlockPort
2023/05/24 18:30:16.352 serial1 asynManager::queueUnlockPort waiting for event
2023/05/24 18:30:16.352 serial1 queueUnlockPort unlock mutex 0x7f605c000e90 complete.
2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort locking port
2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort taking mutex 0x7f605c000e90
2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort queueing request
2023/05/24 18:30:16.452 serial1 addr -1 queueRequest priority 0 not lockHolder
2023/05/24 18:30:16.452 serial1 schedule queueRequest timeout in 2.000000 seconds
2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort waiting for event
2023/05/24 18:30:16.452 asynManager::portThread port=serial1 callback
2023/05/24 18:30:16.452 serial1 asynManager::queueLockPortCallback signaling begin event
2023/05/24 18:30:16.452 serial1 asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort
2023/05/24 18:30:16.452 serial1 asynManager::queueLockPort got event from callback
2023/05/24 18:30:16.452 serial1 flush
2023/05/24 18:30:16.452 192.168.1.5:5001 udp flush
2023/05/24 18:30:16.452 192.168.1.5:5001 udp write.
2023/05/24 18:30:16.452 192.168.1.5:5001 udp write 3
PX;
2023/05/24 18:30:16.452 wrote 3 to 192.168.1.5:5001 udp, return asynSuccess.
     Another loop begin.
*************   AsynTrace out, End ******************
    Since loop was about "px;", I checked driver.cpp, found that "PX" only came out in MCB4BAxis::poll function.
    Here is the code of MCB4BAxis::Poll.
********************* MCB4BAxis::poll Begin *************************
asynStatus MCB4BAxis::poll(bool *moving)
  int done;
  int driveOn;
  int limit;
  double position;
  asynStatus comStatus;
  position = atof(&pC_->inString_[3]);
  setDoubleParam(pC_->motorPosition_, position);
  // Read the moving status of this motor
  sprintf(pC_->outString_, "ID;");
  done = (float(pC_->inString_[3]) > 0.009) ? 1:0;
  setIntegerParam(pC_->motorStatusDone_, done);
  *moving = done ? false:true;
********************* MCB4BAxis::poll End *************************
    Could someone help me with these questions:
    3)
    4)
    if (relative) {
  } else {
   Any suggestion was appreciate.
   Thanks.
Lynn
Re:Re: some motor driver 3 questions lynn via Tech-talk
Prev: Re: opc ua Ralph Lange via Tech-talk
Next: Re: Re:RE: no bin file Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: some motor driver 3 questions lynn via Tech-talk
Next: Re:Re: some motor driver 3 questions lynn via Tech-talk
ANJ, 30 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
