1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Problems when compiling areaDetector out of synapps, but using some synapps modules.
From: Hugo Henrique Valim de Lima Campos via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 29 May 2023 20:36:16 +0000
Hello,
I'm trying to compile areaDetector outside a synApps, but I'm using all modules except AD from it. I defined a new path for area detector in the RELEASE_LIBS.local and RELEASE_PRODS.local like so:
AREA_DETECTOR=/home/hugovalim/SOL/tmp/areaDetector
# ADSupport is needed by ADCore plugins
ADSUPPORT=$(AREA_DETECTOR)/ADSupport
# ADCORE for base classes and plugins
ADCORE=$(AREA_DETECTOR)/ADCore
But when a try to compile it, it seems to have a conflict with the macro $(AREA_DETECTOR) that is defined inside the synApps, the error is that:
Definition of ADCORE conflicts with SUPPORT support.
In this application a RELEASE file defines
      ADCORE = /home/hugovalim/SOL/tmp/areaDetector/ADCore
but SUPPORT at /usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/ defines
      ADCORE = /usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/areaDetector-R3-7/ADCore
Definition of AREA_DETECTOR conflicts with SUPPORT support.
      AREA_DETECTOR = /home/hugovalim/SOL/tmp/areaDetector
      AREA_DETECTOR = /usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/areaDetector-R3-7
Definition of ADSUPPORT conflicts with SUPPORT support.
      ADSUPPORT = /home/hugovalim/SOL/tmp/areaDetector/ADSupport
      ADSUPPORT = /usr/local/epics-nfs/modules/R3.15.6/synApps/R6.1/support/areaDetector-R3-7/ADSupport
What should I do in this case?
Hugo.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Problems when compiling areaDetector out of synapps, but using some synapps modules. Mark Rivers via Tech-talk
Prev: iocStats errors about undefined environment variables Mark Rivers via Tech-talk
Next: Maxnet cant open omsAsyn no such file or directory Mayou Hasegawa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: iocStats errors about undefined environment variables Simon Rose via Tech-talk
Next: Re: Problems when compiling areaDetector out of synapps, but using some synapps modules. Mark Rivers via Tech-talk
ANJ, 30 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
