1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: [EXTERNAL] procServ comminication with phoebus problem
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Hartman, Steven" <hartmansm at ornl.gov>, wang Ewen <ewenwang2021 at gmail.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 2 Jun 2023 13:16:33 +0000
Hi Ewen,
I think you are probably worried about these messsages after iocInit:
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 35429,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2023-06-02T06:34:42.607 Using dynamically assigned TCP port 56505.
Those are normal.  As long as your IOCs and your Channel Access clients are all on the same subnet then there is no problem, and the default behavior without setting EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST will work fine.  If you need to run the client on a different subnet then things get more complicated.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of wang Ewen via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, June 1, 2023 5:41 PM
To: Hartman, Steven <hartmansm at ornl.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: 回复: [EXTERNAL] procServ comminication with phoebus problem
I start run annother ioc: [root@localhost iocmzexample]# procServ -n "my-ioc02" -L my-ioc.log -P 8889 -i "^D^C" /usr/local/EPICS/ioc01/iocBoot/iocmzexample/st.cmd
procServ: spawning daemon process: 4394
[root@localhost iocmzexample]# ps aux | grep procServ
root       3258  0.0  0.0  16928  1272 ?        Ss   06:09   0:00 procServ -n my-ioc -L my-ioc.log -P 8888 -i ^D^C /usr/local/EPICS/iocs/iocBoot/iocmyexample/st.cmd
root       4394  0.0  0.0  16928  1276 ?        Ss   06:34   0:00 procServ -n my-ioc02 -L my-ioc.log -P 8889 -i ^D^C /usr/local/EPICS/ioc01/iocBoot/iocmzexample/st.cmd
root       4444  0.0  0.0 112816   976 pts/2    S+   06:34   0:00 grep --color=auto procServ.
This is the second ioc log:
@@@ Restarting child "my-ioc02"
@@@    (as /usr/local/EPICS/ioc01/iocBoot/iocmzexample/st.cmd)
@@@ The PID of new child "my-ioc02" is: 4402
#!../../bin/linux-x86_64/mzexample
< envPaths
epicsEnvSet("IOC","iocmzexample")
epicsEnvSet("TOP","/usr/local/EPICS/ioc01")
epicsEnvSet("EPICS_BASE","/usr/local/EPICS/base")
cd "/usr/local/EPICS/ioc01"
dbLoadDatabase "dbd/mzexample.dbd"
mzexample_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/user.substitutions"
dbLoadRecords "db/mzexampleVersion.db", "user=root"
dbLoadRecords "db/dbSubExample.db", "user=root"
#var mySubDebug 1
#traceIocInit
cd "/usr/local/EPICS/ioc01/iocBoot/iocmzexample"
iocInit
Starting iocInit
## EPICS R7.0.3.1
## EPICS Base built Dec 16 2022
## Start any sequence programs
#seq sncExample, "user=ewen"
[?1034hepics>
Windows 邮件发送
发件人: Hartman, Steven
发送时间: 202362 0:15
收件人: wang Ewen
抄送: tech-talk at aps.anl.gov
主题: Re: [EXTERNAL] procServ comminication with phoebus problem
On Jun 1, 2023, at 10:59 AM, wang Ewen via Tech-talk <tech-talk at aps.anl.gov> wrote:
[root@localhost iocmyexample]# procServ -n "my-ioc" -L my-ioc.log -P 8888 -i "^D^C" /usr/local/EPICS/iocs/iocBoot/iocmyexample/st.cmd
My phoebus setting.ini is::
org.phoebus.pv.ca/addr_list=192.168.238.134:8888
That is incorrect. In your configuration, procServ is using port 8888 to provide connection to the IOC console it serves. Channel Access is still using port 5064. Try org.phoebus.pv.ca/addr_list=192.168.238.134:5064.
You should be able to telnet to port 8888 to connect to the IOC shell via procServ.
Steven Hartman
procServ comminication with phoebus problem wang Ewen via Tech-talk
Re: [EXTERNAL] procServ comminication with phoebus problem Hartman, Steven via Tech-talk
回复: [EXTERNAL] procServ comminication with phoebus problem wang Ewen via Tech-talk
Prev: Re: procServ comminication with phoebus problem Hu, Yong via Tech-talk
Next: Re: [EXTERNAL] procServ comminication with phoebus problem Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: 回复: [EXTERNAL] procServ comminication with phoebus problem wang Ewen via Tech-talk
Next: Re: procServ comminication with phoebus problem Hu, Yong via Tech-talk
ANJ, 02 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
