1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: [EXTERNAL] procServ comminication with phoebus problem
To: wang Ewen <[email protected]>
Date: Fri, 2 Jun 2023 16:31:29 +0000
Hello Ewen,
I guess you got procServ from https://github.com/ralphlange/procServ . To manage multiple IOCs wrapped by procServ, additional to Mark’s script, you can either use the built-in tool “manage-procs” or use this tool https://github.com/NSLS-II/systemd-softioc
Yong
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Date: Thursday, June 1, 2023 at 7:14 PM
To: wang Ewen <[email protected]>, Hartman, Steven <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: [EXTERNAL] procServ comminication with phoebus problem
Hi Ewen,
  • Thank you for your reply, it's working fine now. I want to run more than one iocs at the same times communication with css phoebus,is it the same port 5064? And just change the ioc name and port?
Yes, you normally always use the same CA port, 5064.
For procServ just change what script it executes to start the IOC, and the telnet port number.
Matt Newville wrote a nice Python script for starting our IOCs, which I have attached.
To add a new IOC you just added it to the IOCLIST.  To start the IOC called 13BMD_XPS you just type
start_ioc 13BMD_XPS
That will also open a telnet connection to the correct port unless the “-s” or “?silent” option is used.
  • Is it can autorestart when the server restart?
start_ioc takes a “-b” or “?onboot” flag in which case it starts all IOCs that are flagged to start on boot.
If the IOC is already running then typing
start_ioc 13BMD_XPS
will just telnet to the correct port.
From: Tech-talk <[email protected]> On Behalf Of wang Ewen via Tech-talk
Sent: Thursday, June 1, 2023 5:00 PM
To: Hartman, Steven <[email protected]>
Subject:
回复: [EXTERNAL] procServ comminication with phoebus problem
Hi ,
Best regards,
Ewen
Windows 邮件发送
发件人: Hartman, Steven
发送时间: 202362 0:15
收件人: wang Ewen
抄送: [email protected]
主题: Re: [EXTERNAL] procServ comminication with phoebus problem
On Jun 1, 2023, at 10:59 AM, wang Ewen via Tech-talk <[email protected]> wrote:
[root@localhost iocmyexample]# procServ -n "my-ioc" -L my-ioc.log -P 8888 -i "^D^C" /usr/local/EPICS/iocs/iocBoot/iocmyexample/st.cmd
My phoebus setting.ini is::
org.phoebus.pv.ca/addr_list=192.168.238.134:8888
That is incorrect. In your configuration, procServ is using port 8888 to provide connection to the IOC console it serves. Channel Access is still using port 5064. Try org.phoebus.pv.ca/addr_list=192.168.238.134:5064.
You should be able to telnet to port 8888 to connect to the IOC shell via procServ.
Steven Hartman
procServ comminication with phoebus problem wang Ewen via Tech-talk
Re: [EXTERNAL] procServ comminication with phoebus problem Hartman, Steven via Tech-talk
回复: [EXTERNAL] procServ comminication with phoebus problem wang Ewen via Tech-talk
RE: [EXTERNAL] procServ comminication with phoebus problem Mark Rivers via Tech-talk
Prev: Re: [EXTERNAL] procServ comminication with phoebus problem Mark Rivers via Tech-talk
Next: Re: Keysight oscilloscope DSOX1204a connection issue Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: 回复: [EXTERNAL] procServ comminication with phoebus problem wang Ewen via Tech-talk
